metro electronic dizzy wiring, HOW?
#16
Posted 25 April 2007 - 07:53 PM
#17
Posted 25 April 2007 - 08:07 PM
Ah yes there's that old favourite stupid wiring diagram again. Why exactly do you now have both a ballasted and an unballasted supply feeding your coil?
If you are going to change to unballasted ignition disconnect the pink/white and white/yellow from the original wiring to the coil and insulate the ends, taping the wires securely back to the loom. Then run your new circuit as in the diagram to replace these.
If you are going to retain ballasted ignition leave the pink/white and white/yellow supplying the ballasted coil and run the new circuit as in the diagram but DON'T connect it to the coil, ONLY connect it to the module supply wire from the dizzy. You don't need both systems.
I'm quoting from earlier, RoadRunner, but is your answer in this post?
#18
Posted 25 April 2007 - 08:16 PM
Just checked the coil and it's a DLB198 whic came with it but I also have a gold coil DBC105, what is that one for? says 12v
Edited by Road Runner, 25 April 2007 - 09:11 PM.
#19
Posted 25 April 2007 - 09:38 PM
Edited by Dan, 25 April 2007 - 09:39 PM.
#20
Posted 26 April 2007 - 06:59 AM
#21
Posted 26 April 2007 - 06:06 PM
#22
Posted 26 April 2007 - 07:32 PM
#23
Posted 11 May 2007 - 08:38 PM
#24
Posted 12 May 2007 - 08:00 AM
To avoid any issues with any ballast resistance that may or may not have been in the wiring loom, I ran another wire from the ignition to the positive side of the coil and left the original loom connection disconnected and taped off. The unit fired up first start and has not missed a beat.
The Minispares recommnded coil for the 65DM4 electronic ignition is the GCL143 - also rated at 0.70 to 0.86ohms.
Non ballasted coils for points systems are rated at 3.0 to 3.5 ohms, while ballasted coils are rated 1.2 to 1.5ohms.
If in doubt about the coil, try a Google search to check the rated resistance, and determine its application from that.
Good luck!
#25
Posted 30 May 2007 - 07:09 PM
hey i have just done the conversion myself do u want a copy of the wiring diagram for the metro dizzy if you
do let me know
Thanks Chewy
Hello
Im a new member and i need a copy of this diagram to in order to save whats left of my hair.Could you email me a copy?.The engines an ordinary Metro 1275 (12HE).
Thanks bundles in advance!.
Martin
[email protected]
