Hi been having trouble wit my carb discovered the bit at the bottom of carb was bent so i replaced the whole carb wit a standard unit in good working order.
Fitted yesterday and ran better than it ever has.Then i parked it up last night and went 2 it 2 day and now its hardly driveable.
Its got no power and is popping and banging from the exhaust .
Only thing is i changed the gasket on the manifold side of the carb wer it attaches to the plate ,i used gasket paper and made it quite thick however i tryed the wd40 spray trick and the revs didnt drop so i guess gasket ok .
How do i adjust the tuning Rich/lean or wotever .it sounds like it sucking to much at air filter.
cheers sorry bout all that but i totaly confused lol
Dave
Carb trouble
dave 17
, Mar 04 2007 05:14 PM
5 replies to this topic
Posted 04 March 2007 - 05:14 PM
Posted 04 March 2007 - 05:28 PM
Did you adjust the carb mix?
Did you fill the dashpot with oil?
Did you put the right sized carb on?
Posted 04 March 2007 - 05:34 PM
yer right carb and dash pot has oil in it .how do i adjust the mix??
cheers
cheers
Posted 04 March 2007 - 05:54 PM
ah. two methods.
1) Life pin, very general way to set up the car. When look at the carb from the engine bay, stick your hand on the left side of the carb and theres a pin with a spring on it It's just below the dashpot housing, main body of the carb. The pin points up. Push the pin up. IF the car dies then it's too lean, so turn the jet adjuster nut (on the sitcky down bit of the carb, jet needle assembly) to the right (when viewing carb from above. Turn a flat, then try the pin again. Keep going untill when you lift the pin the engine rev's up a little then goes back down.
If when you start the engine rev's up (using the lift pin) then it's too right so turn the nut to the left.
2) method 2, get a gunson colour tune, then follow the instructions.
method 1 is cheaper. :D
Posted 04 March 2007 - 06:31 PM
cheers mate will try that
Posted 04 March 2007 - 07:01 PM
Should do it from warm, but if your mini is really acting up do it cold. Go for a drive then do it again to make sure it's right.
