engine stabiliser bolts
Posted 05 March 2007 - 04:14 PM
Anyway, ive started to undo the bolts, which starts to undo, but they dont undo enough to get them out. they just keep turning. ( again.lol)
So how do i get them off. i thought there might be some nuts underneath, but there dont seem to be a place underneath. help plz
Posted 05 March 2007 - 04:17 PM
Posted 05 March 2007 - 04:33 PM
Posted 05 March 2007 - 08:23 PM
Posted 06 March 2007 - 09:28 AM
If this hasnt been done for a while, you may find the bolt has rusted into the metal tube that 'should' be inside the rubber steady bush. If this has happened then you will need to drill/cut the top of the bolt off so you can withdraw it and replace. You can try and bash it out from underneath but you will just end up bending the brackets on the bulkhead as its a *Female doggy* to get at.
The bolt is the same part no. as the one that goes into the block on that steady.
Posted 06 March 2007 - 11:35 AM
You need to get a spanner on the lower nut too, to stop the bolt from turning. it's a damned fiddly job though, but with some patience you'll get it off. Just watch that you don't drop the nut and washer etc.
How do i get to the the lower nut ??
I cant seem to find an etrance to them .. cheers
Edited by Mark1275GT, 06 March 2007 - 11:59 AM.
Posted 06 March 2007 - 04:05 PM
Right easy peasy, you just need to get an assistant to hold a ring spanner securing the nuts which are within reach, up and underneath the passenger side dash/bulkhead area of the inside of the car, whilst you undo it on the engine side of the bulkhead as in the picture.
Edited by taffy1967, 06 March 2007 - 04:07 PM.
Posted 06 March 2007 - 06:12 PM
Now I understand, your referring to the ultimate engine steady thats attached to your thermostat!
Hi. you sure about this. ive looked and looked again, but cant see anyway to get underneath from the inside from the passenger side dash/bulkhead area. had all me dash out...
it's on my 1275GT ?
Posted 08 March 2007 - 12:04 AM
The bolts are not under the actual parcel shelf, their was back under the bulkhead crossmember, so just stick your hand under, reach right back and route around.
I got my nephew to hold the nuts with a ring spanner, so their not difficult to find or hold in place.
Edited by taffy1967, 08 March 2007 - 12:06 AM.
Posted 08 March 2007 - 12:14 AM
...total pain in the arse to do with no assistant tho.
edit
might be under a flap of carpet unless you fitted new flashy carpet in which case it might have to come out.
Edited by Big_Adam, 08 March 2007 - 12:14 AM.
Posted 08 March 2007 - 01:16 PM
They secure were the left hand pedal controls would be in a wrong side drive car.
edit
Yep found them
They were underneath the carpet. what a fiddley job. i can get a ring spanner on 2 of nuts.
but the 3rd one is a no go to get a ring spanner onto. ill have to wait till my Girlfriend gets home, so ill have to use my strong fingers to hold the nut while she undoes the bolts from inside the bolk head..
Wish me luck
Thanks once again for your help lads
Posted 08 March 2007 - 01:37 PM
