electrical "issues"
clubman katie B.F
, Mar 05 2007 05:13 PM
14 replies to this topic
Posted 05 March 2007 - 05:13 PM
evening all....just gonna have a nother go at sorting my electrical gremlins out...any suggestions would be appreciated
i have an engine that turns over
a horn that works
indicators that work on the drivers side.
but flash once on the other side and stay on. i have a new relay fitted.
i have windscreen wipers that work.
i don't have:
instrument dash lights apart from indicator lights, tho the drivers side does come on really dim in sympathy with the passenger side
i have no heater.
no oil pressure or battery indicator lights. the orange and red ones
no side lights front or back. though i have put a circuit tester on and there appears to be a complete circuit here, but no power
the loom has been re-taped and had new bullet connectors fitted.
all connections have been cleaned up
it is an early 2 fuse fuse box
all wires to and from the fuse box are connected as described in "Pains" manual.
all earths have been checked
on the ignition connection there is a green and yellow wire that has nothing to connect to, so i have a red and white wire, two whites and a brown, and a spare blade connection with no wire from the wiring loom.
any ideas would be muchly appreciated
ta
think thats it
a horn that works
i don't have:
i have no heater.
ta
think thats it
Posted 05 March 2007 - 05:22 PM
all you can do is get the wiring diagram out of the Haynes manual and a voltage tester and follow the power from the battery out to see where it stops
your a bit far away for me to look
Posted 05 March 2007 - 05:40 PM
lol bungle i can post a pic tee hee
Posted 05 March 2007 - 05:46 PM
ELECTRICS BAAAAA!!!
They have a mind of their own...
I changed the clutch hose to braided this weekend, I had to move the water bottle to do it.
This morning the washers didn't work. So, opened bonnet, checked wiring, all in place, closed bonnet, got back in car and they worked!!
WHAA!!
It's been a long day!!!!
WHAA!!
Edited by Bass Man, 05 March 2007 - 05:47 PM.
Posted 05 March 2007 - 08:22 PM
What year is your car
Posted 05 March 2007 - 08:52 PM
It's 1971, 1275gt, smiths 3 clock.
heater now working.
had a good look at the circuit board on the back of the clocks and this appears to be shot, as there are breaks in the printed circuits.
tried another set of clocks and everything apart from the panel lights, which leads me to conclude that:
since i have no sidelights, then i won't have any panel lights, if i get the side lights working then....in theory i should get power to the the panel lights.
the problem being i need a new circuit board. i have looked at swapping my circuit boards over, but as the other clock set are the newer japanese set, the circuit boards differ, not by much tho. it's just around the rev counter that they differ, so unless anyone has a printed circuit board for an early smith 3 clock offset instrument panel, they can sell me then i need to learn to solder
heater now working.
Posted 05 March 2007 - 08:59 PM
here is where the circuits differ i have very roughly used paint to show where the early clock rev counter goes
Edited by clubman katie B.F, 05 March 2007 - 09:02 PM.
Posted 05 March 2007 - 10:11 PM
nick
can you post a pic of the other cicuit board so i can have a look.
also i got one in the shed, buzz me on msn tomorrow to remind me to look for you.
as for the side lights whats your switch like? a way to by pass it is with a piece of wire. also do you have headlights
Posted 05 March 2007 - 10:37 PM
You'll need a pre '76 PCB really as the wiring for the tacho system is entirely different. You're fairly lucky to have an ignition system at all in a pre '76 1275GT if the PCB is shot. The tacho runs the ignition system and because of that it may be unwise to use a modified later PCB. I believe these are acutally the most readily available PCBs, the late Nippon Seiki ones are really hard to find as they weren't really available as a service part.
Posted 06 March 2007 - 04:44 PM
I've heard of people soldering or stapeling their printed circuits rather than replacing them. Due to having difficulty getting hold of replacements.
Posted 06 March 2007 - 08:16 PM
got sidelights sorted, so thanks for all your help and advice.....just need a printed circuit....if any one can help here, or know of a supplier that would be much appreciated. have also got the fog lights wired in....these have covers with small holes and lenses in them which look quite cool.
going back to the printed circuit, here is a pic....the one i am after is the one on the left.
Posted 08 March 2007 - 12:22 AM
You could try contacting these:-
Minimail Link
Somerford Mini Specialists Link
If they can't help then I don't know who can?
Minimail Link
Posted 08 March 2007 - 09:29 AM
Don't use the fogs with the covers on them, the windows are there so you can make sure they aren't lilt while the covers are on. The covers are not heat or flame proof.
It might be worth trying Cearbont Automotive Instruments for the PCB, that's what Smiths are called now. They might just know of some hidden away somewhere.
Posted 08 March 2007 - 01:59 PM
Or even Speedy Cables perhaps?
Speedy Cables Link
Which by the looks of it is right by Caerbont Automotive Instruments Ltd! So are they related now in any way?
Well they have Caerbont as one of their Links anyway!
Speedy Cables Link
Edited by taffy1967, 08 March 2007 - 02:02 PM.
Posted 08 March 2007 - 10:56 PM
I think that Speedy was bought by CAI after the CAI management buyout that secured the company. Might be wrong though.
