minisport cam kits
Posted 05 March 2007 - 11:10 PM
Posted 05 March 2007 - 11:13 PM
Edited by Dan, 05 March 2007 - 11:13 PM.
Posted 06 March 2007 - 09:01 AM
Posted 06 March 2007 - 08:31 PM
is this a complete kit or do i have to buy springs and followers seperate?just buy an sw5 less than a hundred quid so save a few extra pennies.
Posted 06 March 2007 - 08:39 PM
Posted 06 March 2007 - 09:41 PM
who makes them tho? i am not too up on engine stuff. i learn as i go!check out the website i have heard you dont need to change the spring just fit a new oil pump also they are allot less than 100 for a regrind
Posted 06 March 2007 - 09:49 PM
You only need new springs if the ones you currently have are either worn out or no good for the spec of the engine you are putting together. You should fit new followers though but these aren't expensive. Get some of the better ones from Mini Spares that hold the bottom of the push rod more securely.
Posted 06 March 2007 - 10:42 PM
cheers! the kits look pretty good! best start saving!Swift Tune.
