lcb
Posted 06 March 2007 - 11:10 PM
Posted 06 March 2007 - 11:17 PM
On mild tune small bore engines tho a cooper freeflow manifold. is what you want.
Edited by Big_Adam, 06 March 2007 - 11:17 PM.
Posted 07 March 2007 - 10:46 AM
Posted 07 March 2007 - 10:56 AM
Posted 07 March 2007 - 07:16 PM
The standard type LCB of which there are many makes, will have a 'y' piece ( 1 7/8")that fits over a 1 3/4" pipe . However the 2" pipe will fit over the ( 1 7/8")'y' Piece.
It gets really confusing now as some people refer to the tail pipe when designating Big bore or Small bore. Playmini and Maniflow use these terms with regards to the actual interconnecting pipes from manifold to back box, so a big bore system is 2" and the small bore is 1 3/4"
Single box 2" systems should be left for turbo engines and 2" twin box systems for highly tuned engines and large cc engines.
Large bore LCB on a 998 is a waste and will do nothing for performance.
The 998 is commonly matched to the Maniflow Freeflow manifold. A 1275 is commonly matched to an LCB. and those who have big cc engines should use the big bore LCB. The 3 into 1 is best left for the race track.
Edited by Mini Sprocket, 07 March 2007 - 07:19 PM.
Posted 07 March 2007 - 07:20 PM
FINALLY! an explanation! cheers mini sprocket! i understand now! any idea where i can get a maniflow system from and how much are they?There is a large bore lcb only for BIG engines 1380 and upwards. This is a two inch system, the 'y' piece (2 1/8")will fit over a two inch pipe.
