Wet Dizzy
Posted 07 March 2007 - 03:10 PM
Posted 07 March 2007 - 03:27 PM
Or apparently a jonny works quite well
Posted 07 March 2007 - 03:31 PM
Posted 07 March 2007 - 03:34 PM
hmmmm, might try them both together, my bird always said johnnys and rubber gloves go hand in hand but thats just her
Posted 07 March 2007 - 03:39 PM
Mini Spares also do a dizzy cover.
Posted 07 March 2007 - 03:46 PM
Posted 08 March 2007 - 01:30 PM
Edited by paulcollins, 08 March 2007 - 01:30 PM.
Posted 08 March 2007 - 01:34 PM
Of course clean and renewed when required electrics are a good way of preventing running problems in the wet and avoiding the use of WD40 also helps too.
Posted 08 March 2007 - 01:35 PM
Posted 08 March 2007 - 01:42 PM
when mine gets wet I just go mad spraying the WD40 everywhere! always works
Yes and that's because your Mini has become dependant on it now. Because once you coat the HT Leads and Dizzy Cap in the stuff it sits there and attracts dust, dirt and grime etc thats blowing through your grille.
Then your Minis electrics start to break down or arc I believe? So you have to spray more WD40 the next time it rains to help provide a good connection and prevent arcing.
If your electrics were clean instead and protected by a weather shield, then you wouldn't need to bother with WD40 in most cases.
In fact i've heard from one Mini owner who runs his Mini with no grille, nor a weather shield and has no problems driving behind lorries on the motorway in heavy rain, simply because he's ensured his electrics are clean. I forget what brand of HT Leads he uses, but their nothing special, just Champion or something similar.
Posted 08 March 2007 - 01:58 PM
Posted 08 March 2007 - 06:23 PM
Is there any old skool meathod of stopping my dizzy from getting wet through. when i'm driving my car in the rain water gets into the dizzy and its runs realy poor.
My mini has the bottom of a plastic coke bottle over the dizzy.
