Hi all,
How do I go about disconnecting the current under-car fuel line from the fuel pipe? How is it connected? I haven't moved the tank yet, but I notice a bit of twisty pipe coming from the tank going through the floor, I can only see 3-4 inches of it.
Why I ask is that I have my fuel line run inside the car now and wish to connect the tank to that line.
Also, the tank is pretty much full-up. Is it worth siphoning to empty first? Any tips?
Thanks!!
Disconnecting fuel line from tank
Daze
, Mar 08 2007 02:42 PM
9 replies to this topic
Posted 08 March 2007 - 02:42 PM
Posted 08 March 2007 - 02:47 PM
The pipe goes onto a small metal tube which is part of the tank, at the back - you should be able to see it if you get your head in the boot. It has a screw-up clip on it. You will have to empty the tank otherwise fuel will *yellow human water* out when you take the hose off....I recently had this pipe split when moving the tank and I assure you it is not fun having a boot full of fuel!!
The pipe goes through a grommet in the boot floor and through to a fuel line which you can see easily enough from under the car. Perhaps you could disconnect this end and allow the fuel to drain out of the tank...
Edited by Minwah, 08 March 2007 - 02:48 PM.
Posted 08 March 2007 - 02:53 PM
Excellent, thanks.
I think what I'll try is jack the back of the car up and disconnect the pipe from below the car, then quickly put a bucket below to catch the fuel.
Thanks!!
Thanks!!
Posted 08 March 2007 - 03:09 PM
I just slide under the side of my El Gordo or wedge myself under the back. Don't know if it's normal to be able to move yourself right under the back of your mini but...meh I can.
Posted 08 March 2007 - 03:14 PM
Lol, cool. Not much chance getting under mine without being jacked up. I can bearly get the jack under there!
Posted 08 March 2007 - 03:40 PM
Too true, I have to drive mine onto bricks before I can get the trolly jack under it!!
Posted 08 March 2007 - 04:08 PM
Really?
How low do you have them!
Posted 08 March 2007 - 04:10 PM
As low as it gets!
Posted 08 March 2007 - 10:37 PM
FGS don't use a bucket. Just drive it 'till it's empty-ish. There's 34 litres in there if you've just filled up. A bucket only holds 10, and will probably be melted by petrol. I can just imagine four buckets of fuel slowly disolving on your drive and suddenly all spilling their lethal contents everywhere as they finally fail. Get some proper fuel cans.
Edited by Dan, 08 March 2007 - 11:01 PM.
Posted 08 March 2007 - 10:52 PM
Ok, no problem. I'll see if I can get my hands on a few fuel cans.
Can't drive the car, doesn't have an engine ... yet!
