a guy in a mini garage local to me said i have a metro 998 in my car he said something about a clutch thingy(cant remember what it was) being shorter than a mini one is he right?
metro engine?
cornflakes5210
, Mar 08 2007 07:45 PM
6 replies to this topic
Posted 08 March 2007 - 07:45 PM
Posted 08 March 2007 - 07:51 PM
I know the Verto clutch is different to the earlier non Verto clutch. But appart from that I always believed that the Mini and Metro shared the same 998cc engine and clutch for some time.
Posted 08 March 2007 - 08:36 PM
I think the Metro has a different clutch slave cylinder - maybe - i can't really remember.
Isn't there also a difference with the Thermostat bypass - mini has one outside the head, Metro's don't - maybe!?
D
D
Posted 08 March 2007 - 08:46 PM
I always thought Metos had cable clutches. The old clutch arms were long and the verto is short.
Posted 08 March 2007 - 09:37 PM
wasn't the thermostat housing differnt too?... or is this removed and swapped for a mini one?
Posted 08 March 2007 - 10:14 PM
It is on the 1275 so would think the 998 is no differant, it has a sandwich plate for the thermastat and bypass.
Posted 08 March 2007 - 10:19 PM
You can't tell by the clutch arm, unless your engine has the late Metro cable clutch arm bodged into a hydraulic system. As said above both cars had the same engine and clutch setup for a long time. Stick up your engine number if you have one (the first half is enough) and someone will tell you where it is from originally.
