Emergency-please help!
Posted 11 March 2007 - 07:00 PM
Last night noticed an extreme clunking from the engine, shaking the whole car. Pulled over at a petrol station and the engine steady bolt that attaches to the engine had fallen out and gone. My engine had about 6-7 inches of movement and the engine was actually hitting the bulkhead when i accelerated. Blue-petered a pen in its place with some packaging tape and drove carefully home.
I then took the same bolt off my old knackered 998, but to my absolute dismay at 11pm last night, the bolt seems too big! I've got an MG metro 1275 and it was finding the hole,but wouldn't engage the thread. But i've checked minispares websitend they only have one size of bolt on there, indicating a universal size.
I bodged the engine in place today so i could get to work, but i'm getting all sorts of problems now. Fuel is plummeting at a rdiculous rate, funny noises are coming from the fan, and I want to cry! I need my car for everything, i live in the styx and am lost without transport.
What bolt do i need/why won't it fit/can i get the bolt from any autoshop and if so what exactly size should i ask for?
Thanks guys!
Posted 11 March 2007 - 07:15 PM
you can get special brackets that you fit when the normal bolt has sheared off, they are a bit like adaptor plates and use other stud holes in the block instead of the original ones, maybe you need one of these ???
Posted 11 March 2007 - 07:26 PM
http://www.minispare....aspx?pid=32758
repair bracket if you need it. Bolts to the flywheel housing.
Posted 11 March 2007 - 07:30 PM
its kinda hard to drill out, so now i've just got a head steady and the engine hardly moves!!!
Posted 11 March 2007 - 07:34 PM
that and the UES is a pain in the arse to work around,.
Posted 11 March 2007 - 08:45 PM
So it might be worth contacting them to get the exact O/E size you need.
I also hear that the bolt holding the engine steady on the bulkhead bracket should be identical, so you could undo and remove that to test.
Good excuse to replace/renew the bushes anyway?
Posted 11 March 2007 - 10:46 PM
Are you sure the old bolt isn't still in the hole preventing the new one from threading? It is far more common for it to snap than fall out.
And as above, don't rely on an Ultimate Engine Steady only. That can lead to real damage. It is very bad to drive the car with no steady rod fitted.
Edited by Dan, 11 March 2007 - 10:48 PM.
Posted 11 March 2007 - 10:53 PM
Even just one of the KAD lower engine steadies and the standard head steady will pretty much stay dead still.
Posted 12 March 2007 - 04:08 PM
I've also just found I've got petrol in my oil, as well as an oil leak from my sump plug. Woe is me!
Posted 12 March 2007 - 05:32 PM
Just taken the breather off the clutch so i could swivel the engine steady out the way and see the thread... and the bolt's snapped. I rally don't want a repair kit as they're £20. Is there any way to remove the broken bolt from the hole?
Is the bolt protruding beyond the hole? If it is then you could get a nut welded on the end, so your able to then unscrew it out. If there's nothing protruding, then it's not easy to get the bolt out with the engine in situ. You could ask a local engineering firm for help, because they may have the necessary tools or a drill small enough to fit between the engine and inner wings, but fitting a repair bracket would solve the problem in no time, even if you wanted it sorted properly afterwards. I believe Mini Spares are trying to get those repair brackets manufactured by another company since the owner of the other one retired.
If there's petrol in your oil then you shouldn't drive your Mini because it's now a very effective bomb. Sounds like the petrol pump seal has gone perhaps?
As for the sump plug, just fitting a new washer after you've treated it to an oil change usually works. So long as you tighten it up correctly and the threads haven't gone.
Posted 12 March 2007 - 06:57 PM
i got them from a small local buisenss, but there made buy draper so someware should have them.
and drilling the pilot hole---NOT EASY, dont think you can use a cordless, i had a air powerd drill so its quite small.#
good luck
Posted 12 March 2007 - 07:44 PM
Posted 12 March 2007 - 08:15 PM
I was already poor this month, now I'm barren!
Posted 12 March 2007 - 10:59 PM
I am surprised that they now have the bracket in stock. Maybe it depends on which of the four types you ordered?
Posted 12 March 2007 - 11:45 PM
Thanks for all the replies guys!
