Spot lights issue
Posted 12 March 2007 - 01:48 PM
The car H reg 1275 Cooper, it was fitted with 4 spots to the front grille which are wired in and working, apart from they seem to only come on with dipped beam and go off with main beam, which is really annoying as I can't drive it at night due to me blinding everyone on the road.
Am I missing something really simple here? because it seems they are wired arse about face what would I be looking for? would it be a simple case of switching some connectors round between dipped and main beam?
Any ideas?
Si
Posted 12 March 2007 - 02:02 PM
Just wondered if anyone could shed any light on this.
Any ideas?
Si
Wired on the wrong cable?? relay missing?? im not sure really but i have put spot lights on a lorry and you need to make sure its coming off the full beam wire.
Posted 12 March 2007 - 02:08 PM
I'm going to remove the grille and do a bit more of an investigation as I'm sure they have connected something on the wrong way.
Where abouts is the full beam wire located? I can see whats connected to it then, if anything.
just been reading this:
http://www.theminifo...showtopic=19353
so I'll have another check later.
Posted 12 March 2007 - 05:02 PM
Earth is the Black wires
Sidelights are Red/Red with Green
Headlights are thick Blue with Red
Main Beam thick Blue with White
I've got the same model Mini Cooper as you and mine had a pair of spots fitted when I bought it 13 years ago. But they weren't the usual Rover type and I removed them a few years later because they were earthed on the front panel and because the fixing brackets had rusted, they stopped working.
Anyway there's still a little relay mounted on the rear/left hand side of my engine bulkhead (just behind the servo) and that just had a wire running from the main fuse box (top I think?).
But of course mine only had the 2 driving lamps which should work with the main beam, where as the fog lamps should work with the dipped lights on a seperate switch.
Edited by taffy1967, 12 March 2007 - 05:04 PM.
Posted 12 March 2007 - 05:58 PM
just swap the wire onto the other terminal
Posted 12 March 2007 - 06:16 PM
I've also lost power to the passenger side headlight so I think by the sounds of it there is a dodgy earth under there as well, think I'll take the grille off and have a proper investigation now I know what I'm looking for.
Let you know how I get on.
Posted 12 March 2007 - 07:37 PM
