Two unknown connectors
Posted 12 March 2007 - 07:45 PM
There are these...
DSC00078_medium.JPG 68.34K 7 downloads
And they come off a loom here...
DSC00079_medium.JPG 73.91K 3 downloads
Its the black wire I have going up over the wing in the photo.
I have no idea what they should be connected to, help!
FWIW I have a non-working rev counter atm, but didn't have time tonight to do a continuity check on these, and the ones plugged in the rev counter.
Posted 12 March 2007 - 07:49 PM
could be the answer...
Edited by Retro_10s, 12 March 2007 - 07:51 PM.
Posted 12 March 2007 - 07:51 PM
does your brake fluid resevoire cap have two spade connectors on?
Only one that I could see!You can see it (just) as the shiny bit above the two connectors in the top photo.
I assume another should be on the opposite side??
Posted 12 March 2007 - 07:52 PM
yes
Posted 12 March 2007 - 08:04 PM
Do your wipers park themselves? If they don't then replacing the wiper motor park-switch will sort that and probably get your tachometer working again.
I and many others have found that the park-switch creates a short circuit when it fails and can cause fuses to blow and gauges to misread if not replaced.
Posted 13 March 2007 - 08:58 PM
You can buy replacement caps.
Moving slightly off topic (ye gods!) I've replaced the park switch and the wipers now park. However, no tachometer. I haven't had a chance to check if I'm getting 12v to it yet, but all fuses I could find (four in fuse box, three in line behind the air filter housing, and one beside steering coloumn) tested ok on my multmeter.
Edited by navvie, 13 March 2007 - 10:19 PM.
Posted 13 March 2007 - 09:55 PM
Mini Fuse Link
Make sure the 4 fuse box is working properly on each terminal, apart from that check that the coil connections are tight and then after that there's only the rear of the clocks themselves. And there's only 2 connectors on the rear of the rev counter?
