driveshafts, brakelights
jonbott
, Mar 13 2007 04:23 AM
11 replies to this topic
Posted 13 March 2007 - 04:23 AM
how easy are they to replace?
looking at a mini later today and told no brake lights and needs driveshaft doin
If I buy it I`ll get a haynes
Posted 13 March 2007 - 08:13 AM
Drive shaft or CV joint, as the shaft is only a piece of metal...
Brake lights are easy, just a matter of finding out why they don't work, either bulbs or the brake switch on the pedal box.
Posted 13 March 2007 - 08:21 AM
the cv joint is easy no?
Posted 13 March 2007 - 09:24 AM
Yes and no.. you need to remove the hub to get the CV off, which with old ( potentially non runner ) minis can prove an issue because of stuck ball joints... but if changing the CV, it's a goot time to inspect the wheel bearings and hub condition generally...
Posted 13 March 2007 - 10:53 AM
You might have trouble getting the inner joint out, I bought the correct tool for this, have used it quite a few times now and its kinda paid for itself in time. You will also need a socket to remove the hub not and I find that having the ball joint socket is also a good investment.
Personally I found the job easy, although I didn't run into any obstacles. Thats when things get difficult, siezed componants etc might double the time you would spend usually. When reassembling items make sure you correctly grease that which need to be greased and also putting copper ease on ball joint swivel pins will make them so so so much easier to split next time round....and wire brushing everything...
Posted 13 March 2007 - 03:56 PM
the car`s a runner just short tax n test,which worries me a bit,been looking for a mini for a while,now found 2 locally I like ones an early and ones a later one hmmmmm
Posted 13 March 2007 - 03:59 PM
Get the one with the least rust, everything else is cheap and easy in comparison!
Posted 13 March 2007 - 04:01 PM
actually goin off track are later minis easier to maintain?Get the one with the least rust, everything else is cheap and easy in comparison!
Posted 13 March 2007 - 04:55 PM
LOL, that's a big can of worms and opinions differ! It also depends as to what you call later, but IMHO the very last ones had more things to go wrong (cats, injection etc) and from what I've seen rot even worse than the earlier ones.
I'll give way for people to argue the opposite though, as I've not had the ownership experience.
Posted 13 March 2007 - 04:59 PM
I`ve looked at the minispares and the bits that are needed for the older mini seem cheap enough the owner seems nice too watch this space by the end of today I`ll prob be a mini owner(again!)
oh the late ones an 85
Posted 13 March 2007 - 05:13 PM
anything pre 86 are usually pretty good, the bonus with an '85 is it'll have disk brakes as std, I don't know how early the other one is, but may still have drums on thr front.
Posted 13 March 2007 - 05:28 PM
def its a 73anything pre 86 are usually pretty good, the bonus with an '85 is it'll have disk brakes as std, I don't know how early the other one is, but may still have drums on thr front.
