Sorry for the vagueness on this!
Well about a month ago i noticed a kind of thudding noise sometimes when i changed gear around the dashboad/steering column, but i got used to it and forgot about it, now today its got alot worse! basically when i change speed it does it, changing gears always does it and a bumpy road makes it do it like crazy!
As far as i figure its just something loose like the clocks aren't held tight or something but it doesnt seem to be that! could it be something bad or is it most likely something just hitting something else?
Rattling
Globule
, Mar 13 2007 02:35 PM
6 replies to this topic
Posted 13 March 2007 - 02:35 PM
Posted 13 March 2007 - 02:55 PM
Is it like a low 'clunk' or more of a tinny rattle?
Posted 13 March 2007 - 03:15 PM
its a low clunk! someone said before could be engine mount but its fine!
Posted 13 March 2007 - 03:17 PM
How have you tested the engine mountings? Get someone to blip the accelerator while you watch to see if the the engine rocks (er, in neutral).
rock the engine back and forth to see if there is any play in the engine stabiliser the bushes may be worn
Posted 13 March 2007 - 03:41 PM
I tried to rock the engine and it didnt move at all, but about watchign the bolts, it only makes the noise when its moving and i dont see me laying underneath a moving mini!
Posted 13 March 2007 - 04:26 PM
Rocking it with your hands isn't enough... An engine has way more power to try and move itself compared to a human... You need to check engine mounts whilst someone blips the throttle for you.
