Coughing and Spluttering
4 replies to this topic
#1 MikeyB
MikeyB
  • 65 posts
Posted 13 March 2007 - 04:01 PM
Hi
my mini is Coughing and Spluttering and i do not know why the timing is bang on. but i have an turbo CAM in an stardard 1275Gt engine also the spark plugs are getting very wet with fuel. Also when stop Coughing and Spluttering after reving the engine its like its back firing through the carb but its not
anyone know why this is happening :'(
Edited by MikeyB, 13 March 2007 - 04:07 PM.
#2 tino
tino
  • 805 posts
Posted 13 March 2007 - 04:10 PM
Could be that you are overfueling the engine seeming the spark plugs are wet.
Check the air/fuel ratio would be where I would start.
#3 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 13 March 2007 - 04:22 PM
Will a turbo cam even work on a NA engine ? I suspect the fact that your using that is causing a few issues.
#4 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 13 March 2007 - 04:26 PM
Sounds like it needs a good tune up as a minimum.
How come you have opted for a turbo cam in a N/A engine by the way?
#5 MikeyB
MikeyB
  • 65 posts
the turbo cam in there because i used to have a turbo on the engine but it started to smoke
