Small problem... i have recently filled up the windscreen wash tank in the back of my mini but no windscreen wash is coming out when i want to clean the windows!
I have stuck a needle down the shoots at the front but these are not clogged so im wondering what the problem is, can anyone offer any advice or resolutions?
Also, i have noticed minispeed sell radius arms which are half the weight of factory spec ones. Has anyone had these or similar ones installed and is the weight reduction enough of a baring factor to improve accelaration?
Windscreen Cleaner
CooperTrooper
, Mar 13 2007 05:26 PM
6 replies to this topic
Posted 13 March 2007 - 05:26 PM
Posted 13 March 2007 - 05:53 PM
it's quite a common problem for minis with the washer bottle in the boot to loose the use of the jets.
assuming the pump is working then it's usually the pipe that runs through the car getting kinked somewhere.
if you cant get any fluid at all, the only thing is to trace the pipe and look for kinks.
Posted 13 March 2007 - 05:55 PM
yeah the pump is working fine-ill take ur advice and have a look - Ta pal
Posted 13 March 2007 - 06:20 PM
check the hoses for kinks, also make sure the fuse box hasnt been screwed down on the hose (ashamed to admit i did this once lol)
Posted 13 March 2007 - 07:17 PM
obvious i know but check the pipe is actually pushed onto the washer jet under the scuttle
when i put my new jets in i didnt push the pipe on well enough so it came off, then i went to test them and nothing came out, but covered my engine in washer fluid
M
M
Posted 14 March 2007 - 12:05 AM
ahh wicked i will check all of the above!! i thought i may have filled the tank too near to the top at first!
thanks for the responses
Posted 14 March 2007 - 12:36 PM
Problem sorted - there was a kink in the tube which meant no water was getting to the jet and to my poor dirty windscreen! Thanks again for responses
