Hi my first post so hi everybody, Well just finshined rebuilding my mini and i need some help. The mini is a 1982 mayfair, but the engine is out of a 1990 metro. Can i use the no verto type slave cylinder if i swap the arms over, or is it not as simple as that. will i have to use the verto type anyhelp thanks.
CLUTCH SLAVE CYLINDER
craig_trigg
, Mar 14 2007 07:36 PM
2 replies to this topic
Posted 14 March 2007 - 07:36 PM
Posted 14 March 2007 - 07:38 PM
i am thinking you need to use the verto type cylinder, something to do with angles and things.
Posted 14 March 2007 - 07:42 PM
yes you will need to use a verto slave cylinder as they work slightlly differantlly, chamber size and amount of movement, not too sure on the exact specifics
