Jacking up the rear end......
biggav
, Mar 14 2007 08:32 PM
19 replies to this topic
Posted 14 March 2007 - 08:32 PM
I'm doing my rear subframe tommorow ad need to work safely(ish) under the back of the car.......
I have a large slab of concrete in the back garden with a 12 inch step in to the garden so im planning to reverse off of the slab on to some blocks, jacking up the centre of the car and using axle stands and timber to hold it then removing the blocks..... i should then be able to remove the subrame... right????
[attachment=29157:JACK.bmp]
Posted 14 March 2007 - 08:40 PM
Move the timber and axle stands further back, so that the car is supported just in front of the rear subframe. This is the strongest area, and will support the full weight of the car...
Posted 14 March 2007 - 08:45 PM
Yeh if its too far forward.. ur cars going to see saw!!
Posted 14 March 2007 - 09:42 PM
My pic was for illustration only!!!!!! I'm starting at 7am wish me luck!!!!!!
Posted 14 March 2007 - 10:27 PM
good luck and as above move the timber back a bit
and don't forget to start squirting the penetrating oil on tonight
Posted 14 March 2007 - 10:38 PM
Yes, the timber as far back as possible. The strongest area of anything is near a corner or bend. Spread the load as much as you can, perhaps use more wooden supports.
Posted 15 March 2007 - 10:20 AM
Mrs biggav wouldn't let me!!!
I have 3 spare alley cats with tyres and i used them underneath the car to spread the weight over a larger area. Feeling a bit shakey though and the doc has given me diazepam to counteract the anxiety that the anti depressants are causing so things are going a bit slowly... plus the kids are off school sick so i'm being called in the house every 5 minutes!!!
I hadn't really planned to start this so soon so still have a full tank of bp ultimate which i'm siphoning out in a mo.
Thanks to the wonders of modern technology, i have the Laptop in the boot of the car so i'm working on the car and on TMF at the same time!!!!
I'm taking loads of photos of this so that anyone else doing rear beam and coil overs have an idea of What not to do!!!!
Posted 15 March 2007 - 10:44 AM
Bigav watch out for the diazepam the doc gave me some for my back(blue ones) to help me sleep, knocked me out for 18 hrs made me zombe like . so if you are working on the car be carefull mate.
Posted 15 March 2007 - 10:59 AM
when i did mine i got two nice big 4x4 tyres and few bits of timber and it was stable and great. i would do a rear subframe again i found it fun......lol
Posted 15 March 2007 - 11:37 AM
axle stands and a scafolding plank is what I use...
Posted 15 March 2007 - 12:37 PM
got big wheels, axle stands and wood.... got the wheels off, battery out, tank empty and out, hole for right hand tank has been drilled and i have test fitted it!!
Plus gassed all of the bits i need to remove underneath wrapped it back up... got to go to hopsital for baby scan!!!
Once back, i'll diconnect the brakes, and srop the sub out as per Haynes Manual.
Got to prime and paint the beam axle.
Posted 15 March 2007 - 01:05 PM
Class hope it all goes well! i had a bolt snap of on mine lucky to get it out.
Posted 15 March 2007 - 08:01 PM
Got back from Hospital just after 4pm and had to go out for kids parents evening at 5
All the subframe bolts are out, handbrake cable disconnected... its still under the car as i couldn't get the brake tee piece apart (more plus gas!!!) and i haven't taken the shocks out yet the radius arms have axle stands under them and if i find my haynes manual, things may hopefuly get somwhere in the morning.
Going to take my drugs and have a good nights sleep.
Posted 15 March 2007 - 08:04 PM
Dont u have any of those rampy thingys? for driving ur car onto?
Posted 15 March 2007 - 08:20 PM
yeah.... but they aint no good if you are taking wheels off.... let alone subrames!!!
