advice on adding a stage 3 to a 998!
Posted 16 March 2007 - 12:53 PM
Posted 16 March 2007 - 01:21 PM
i have recently purchased a 998 in good condition and am toying with the idea of adding a stage 3 from minisport to add a little extra woomph with my next paypacket. the kit includes: modified performance cylinder head, polished ported and gas flowed, incorporating 29mm larger inlet valves and increased compression ratio; twin 1.25 inch carburettor with heat shields, alloy inlet manifold and linkages; a sportex dual exit 3 inch tailpipe (extra) ; long centre branch exhaust manifold; KN air filters; head gasket, rocker gasket; manifold gasket; carb gasket and thermostat gasket. i will also after fitting take it to a rolling road for some extra tweaking. kit claims a 50% power increase and turn your mini into a truly responsive mini all for £861! has anyone any experience in doing this to a 998cc and is it worth it or shall i spend my money on other mods, any recommendations and advice will be helpful. im also thinking of adding some thirteen inch wheels aswell has anyone any idea on loss of power in doing so! thanks
I have spoke to loads of people about modding a 998cc and the same answer i keep getting is basiclly why spend the money on a engine that you cant really modify that much?!? why not get a 1380 or 1275 or somethink in that range. when you get get more bhp out of it, with the money your looking at spending on the engine is it really worth it? to be honest i wouldnt do it.
Hope this helps
Posted 16 March 2007 - 01:26 PM
If you just want extra oomph, then buying a stock 1275 will do that...
buying an upgraded engine kit, say 1330 or 1380, will give you probably double the grunt of a stg1 998, and for less pennies than your spending on your stg3 998..
ps. forget the exhaust, that'll just remove a lot of the power you're trying to gain... stick with a 1.75" exhaust system
Posted 16 March 2007 - 02:52 PM
But yeah as has been said if you want power, get a bigger engine!
Dave
Posted 16 March 2007 - 07:16 PM
Posted 16 March 2007 - 07:24 PM
make sure you get it setup on a good rolling road, it mite also be worth checking to see if there is a better distributor to suite that engine spec too!
Posted 16 March 2007 - 07:27 PM
Posted 16 March 2007 - 09:07 PM
"you cant cant modify it that much"! what are you talking abuot?? I think im right in saying the phrase "anything you can do, i can do better", basically anything you can do to a 1275 or 1380 or even a 1410 you can do to a 998 (within reason).
The guy alerady HAS a 998 so why bother gong out and spending money at MED or morspeed or anywhere else and buy a block when he can tinker abuot with his 998? Small bore "racers" are coming back into fashion, i think this forum has about 20+ members doing small bore engines.
Ok so a "Standard" 998 might not be quick, the reason i say "Might NOT be" is because you get 'unusual' engines, and not just 998s. Every now and then you find a standard engine that goes like stink. Alas last year i got 106mph out of my car, the engine then was a 998 with RC40 and a AAU needle! nothing special, so hopefully with a few new "toys" it might fetch a little more.
Please have a look at JetBLICKs project and mine. We are oth doing small bore engines. Dan (JetBlick) has already got himself 63bhp out of a 998! I myself am aiming for near enough 100bhp FROM A 998 WITHOUT Forced induction!!
People i have talked to have said "ahh impossible without turbos or superchargers" hmm ok look at the mini se7ens!
to be honest (and probably harsh) i feel that post was completly unhelpful. Ok so you suggested what everyone suggests "Get a bigger engine". so many people asked me "why a 998, why not a 1275?" well to be blunt, why SHOULD i get a 1275 etc?
Not only do you have the engine to think abuot, but as Minidave pointed out, wheel size will be an option. Would you rather get quicker acceleration (10s) or higher top speed (13s), or maybe somwhere in the middle (12s).
at the end of the day it IS completly upto you, but im fed up of people slating smallbore engines and asying "ooh get a 1275 or a MED 1410" they might as well say "ooh get a KAD126v or Z-cars, or a ferrari mini engined!!"
Rant over lol
Hope you find this somewhat helpful. the projects will hopefully help you out.
Posted 17 March 2007 - 11:21 AM
Posted 17 March 2007 - 11:34 AM
Posted 17 March 2007 - 11:35 AM
Posted 17 March 2007 - 07:04 PM
As for insurance if you stick a stage 3 head on it will probably be the same if not more than a 1275.
But its upto you. As you stated you have a 998 and its only done 27000miles so id stick with it. If not, ill buy it off you
Posted 17 March 2007 - 07:12 PM
i agree about one off standard engines. one of my old 998s was a damn sight quicker than my old spi cooper. it was an absolute gem to drive, i also think if you can afford to have a play with a 998 then go for it. if u want a finished article type engine then go bigger. it will be interesting to see what u can get out of yours mate!why spend the money on a engine that you cant really modify that much?!?
Rant over lol
Posted 17 March 2007 - 07:23 PM
mini se7ens are race cars
engines stripped after so many races would not be very pratical to strip your engine alll the time for road use
just my opion
but pocketing the block to run a 12g940 head is a good idea and a lot cheaper
i have a stage 2 998 unleaded head for sale if you dont want to pocket the block
dont have to spend over £800 to get good power from a 998
Edited by THE STIG, 17 March 2007 - 07:25 PM.
