bottom pulley
26 replies to this topic
#1 miniman86
miniman86
  • 1,939 posts
Posted 18 March 2007 - 06:07 PM
need to do timing chain tensioner on red mini, got rad out, undone engine mount on nearside of car, jacked up engine a little, got socket onto it, put car into gear and chocked wheels, pulley turned and car managed to move the chocks! so how do i manage to undo the bolt without the bloody engine turning??
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 18 March 2007 - 06:24 PM
Right,
Tap the tab of the washers back. Then plonk the socket on the back. Put the engine in top gear, hand break hard on AND bricks under the wheel.
Then take you ratchet or breaker bark and extend it. I used a bike seat post for an extra 2 feet on my foot long ratchet handly.
Then!
(this is easier with the bonnet off) take a large hammer and :) thwak the bar to shock the bolt off. Took my two good hits to undo mine the 1st time.
Might do with a rag to protect pain around the area were the bar might hit.
edit
....why did you unto the engine moutn? I just too the bottom rad mount off then get the socket on, then again mine are stepped.
Edited by Big_Adam, 18 March 2007 - 06:24 PM.
#3 miniman86
miniman86
  • 1,939 posts
Posted 18 March 2007 - 06:33 PM
most prob didnt help that i didnt undo the lock tabs whoops :) i didnt undo the engine mount from subby, undid the two bolts that bolt the thing to the gearbox, that is between the gearbox and the mount, that the rad sits on top of, duno what its called!! only beacuse couldnt get socket on straight. i was also trying to use a torque wrench, would you recommend a breaker bar then?
#4 Big_Adam
Big_Adam
  • 7,435 posts
Posted 18 March 2007 - 06:34 PM
Oh no, don't use a torque wrench like that. You'll break it.
I don't have a breaker bar. I just use my cheapo socket with a bar on the bottom.
I'll do a pic to show. Back in a few.
#5 miniman86
miniman86
  • 1,939 posts
Posted 18 March 2007 - 06:40 PM
ok mate ta!
#6 Big_Adam
Big_Adam
  • 7,435 posts
Posted 18 March 2007 - 06:43 PM
the B.A. ULTRA budget bar. Done me proud so far. Although be prepared if you break your ratchet.
[attachment=29378:P1000082.JPG]
#7 miniman86
miniman86
  • 1,939 posts
Posted 18 March 2007 - 06:59 PM
a ha i see!! well i wont be trying that with my snap on one, but there is an old one at work i can 'borrow'!! cheers for that!!
#8 Big_Adam
Big_Adam
  • 7,435 posts
Posted 18 March 2007 - 07:04 PM
Why not, span on have a life time warrant on them. They break you get a new one. My dad uses them in Libya.
Then again they are fuggin expensive. My one is from a homebase set I got a few years ago.
#9 miniman86
miniman86
  • 1,939 posts
Posted 18 March 2007 - 07:08 PM
just saves hastle of breaking it!! plus there is an old 1 at work so may aswell use that! haha!
#10 Big_Adam
Big_Adam
  • 7,435 posts
Posted 18 March 2007 - 07:10 PM
Nice, hope it all works out for you. Tis a pig of a job to do.
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 18 March 2007 - 07:12 PM
Oh Adam your poor ratchet! Please don't abuse tools like this!
#12 Big_Adam
Big_Adam
  • 7,435 posts
Posted 18 March 2007 - 07:21 PM
Work with what you got. I had to so I did.
I'm a horrible tool abusing person. Always get a clean up afterwards tho.
#13 blacktulip
blacktulip
  • 6,224 posts
Posted 18 March 2007 - 08:12 PM
i have a breaker u can borrow alex. if u want to borrow ill bring it wednesday.
#14 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 18 March 2007 - 08:14 PM
alex, 4th gear is probably better and have someone else in the car with their foot on the brake.
#15 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 March 2007 - 09:39 PM
or... remove starter motor and lock flywheel with large flat bladed screwdriver between starter ring and transfer case, saves screwing (lol) around with all this in gear, hand brake on, foot one pedal poop.
