bottom pulley
26 replies to this topic
#16 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 19 March 2007 - 11:01 AM
I'm a horrible tool abusing person. Always get a clean up afterwards tho.
Sorry, but LOL at Adam! =]
PS: Don't abuse your tools!
#17 Big_Adam
Big_Adam
  • 7,435 posts
Posted 19 March 2007 - 11:41 AM
........damn
Just realised how ....."weird" that sounds.
#18 miniman86
miniman86
  • 1,939 posts
Posted 25 March 2007 - 11:00 AM
or... remove starter motor and lock flywheel with large flat bladed screwdriver between starter ring and transfer case, saves screwing (lol) around with all this in gear, hand brake on, foot one pedal poop.
i was just about to post that ive tried chocking the wheels and having someone on the brakes (faye!) but now i know how to do this! well so long as it does work!! if this fails any other ideas??
#19 Phaeton
Phaeton
  • 1,055 posts
Posted 25 March 2007 - 11:20 AM
As long as you can get right onto the pully nut (might mean taking rad out on Mini) using a GOOD CORRECT fitting socket with a tommy bar, have the tommy bar against the subframe & flick the starter. Thats worked for me on every other car I've done.
Alan...
#20 miniman86
miniman86
  • 1,939 posts
Posted 25 March 2007 - 07:50 PM
rad is out, socket is shall we say 'loose' (34mm closest ive got) what size is the bolt??
#21 Phaeton
Phaeton
  • 1,055 posts
Posted 25 March 2007 - 08:54 PM
Not sure but it does have to be a good fit, engine needs to be bolted back in car. Just a thought if you are in front of the car & you have it in gear with brakes on you are pulling the lever towards you?
#22 rozzer!
rozzer!
  • 2,367 posts
Posted 25 March 2007 - 09:37 PM
33 is the closest mm size bearing in mind that mini is imperial not metric! drop into me after work as i have the correct size to undo the bolt.
#23 Big_Adam
Big_Adam
  • 7,435 posts
Posted 26 March 2007 - 12:05 AM
nah, 34mm. That what I used. 1.5inch is a bugger to find.
#24 miniman86
miniman86
  • 1,939 posts
Posted 02 April 2007 - 03:04 PM
right bottom pulley and casing off now thanks to fifif!!! now put on new tensioner and on full tension it is sitting about 10mm away from the chain, any other ideas?
#25 Big_Adam
Big_Adam
  • 7,435 posts
Posted 02 April 2007 - 03:16 PM
Pictures?
#26 rozzer!
rozzer!
  • 2,367 posts
Posted 02 April 2007 - 08:48 PM
actually the 33mm that i lent miniman 86 was a fraction bigger than the crank pulley bolt.
#27 rozzer!
rozzer!
  • 2,367 posts
Posted 02 April 2007 - 08:50 PM
is there a spring that goes with the tensioner to push the tensioner against the chains?
