Does the car have a tach? If so, watch the tach as you rev the car. When the engine dies, does the tach needle fall to zero instantly (ignition system fault) or does the needle drift toward zero (fuel or other fault)?
If the tach falls instantly to zero, look inside the distributor. Check the points as I mentioned in a previous post and also look for the grounding wire that runs between the breaker plate and the shell of the distributor. The points need to be gapped properly and the flexible ground wire needs to be in place. While you're in there, make sure no wires are loose that may be touching ground when the car revs and the advance plate moves.
im not really sure what a tach is pal but im pretty sure i dont have one, just revs and speedo.
i just went down again and tried starting it, no luck. Looks like i'll be replacing the windows tomorrow then
think it'll help me getting it started tomorrow if i charge the battery tonight.
also, anyone want a 1987 mini advantage with like 40k on the clock? I'm getting fed up with it.
