Ah yes, see what you mean, I would use 1/4 inch rubber edging trim on those.
Was any thing else on the failure sheet? If so can I have a look?
Cheers Ian
The failure sheets looks like war & peace but it's not really that bad, it's all cosmetic none 2.5mm radius's mainly. The only mechanical thing was the brackets for my handbrake were flexing & they didn't like that so I've had to beef them up. There was little bits of wiring that weren't in sleeving that could chaf, the pipe i had used between brake resivior & master cylinder wasn't marked so they wanted a specification sheet on it, I'm not able to supply one so chainging it for one I can. I had used clear braided fuel line & they want that changed. All little niggly things, have you had yours SVA'd yet? if not & you can getthere I would reccomend Nottingham, although they failed it on quite a number of things it was all very fair.
If you want to follow my progress i'm trying to keep a thread updated on
muddybuggies.com Alan...
