Sorry to go O/T, I think I misunderstood your first question. I thought you were asking the pros and cons of caliper conversions from salvage yards, which is why I harped on about the Fiesta conversion.
If you refer to using the fiesta caliper with the 7.5 disc then it's on topic.
But I have not read any threads where it was actually done. Seemed to be a lot of worry with the amount of grinding to clear the hub.
If it can be performed by just bolting on a set of 7.9 rotors during a brake job then it may be a viable option in the future if I need to replace the rotors.
But it sounded like the upgrade to Fiesta calipers was an all or nothing conversion which means all the 7.5 brakes would be removed and replaced!!! Not a very economical upgrade. Relitively speaking.....
So I was asking if there were any other caliper swaps using parts from the breakers that will increase the contact area.
I just figured that as long as the mini has been raced that someone/many have already come up with simple parts upgrades. I thought the metro 4 pot would be an option but the more i read the less it seems to be a real improvement.
Maybe the design of the mini hubs and rotors limits the options out there. Along with the 10" wheel space.
So far i have only installed the 7.5's and found them fair in braking. quite a bit of pressure required. But better then the drums.
I just recieved my SS lines and new pads but will have to get the number off of them to be sure what I ordered.
Thanks for the inputs so far. I appreciate any and all.
I'm just trying to concentrate on getting the most out of the 7.5's.
Maybe I'm asking too much from them.
