can anyone help me out asap so i can pull out of the sale if nessary?
thank you so so much for any help hehe phil.
Posted 22 March 2007 - 12:54 PM
Posted 22 March 2007 - 01:28 PM
Posted 22 March 2007 - 07:11 PM
Posted 22 March 2007 - 11:18 PM
If you overdo it it WILL pop off. Mighty Mini racers fit a chunk of foam onto the bonnet right above the filter to help stop this happening.
Posted 28 March 2007 - 12:13 PM
Posted 28 March 2007 - 05:40 PM
Posted 03 April 2007 - 03:47 PM
Posted 03 April 2007 - 04:23 PM
Posted 03 April 2007 - 04:53 PM
Yes, you deffo need the air temp sensor in the filter housing, on the car. They can be tight, make syre you use a correctly fitted spanner. If it wont budge and you end up damaging the sensor, then its a new sensor im afraid. It should move though if you git it some heave ho. Things are fitted for a reason, no good thinking you can get away without them
And yes you need to block off the red pipe that should have a brown elbow on the end, that originaly fitted to the standard air filter housing. The pipe itself should still be fitted to the back of the manifold. You could alternatively remove this pipe altogether and block off the port on the manifold, if you have the means to do this.
Posted 08 April 2007 - 11:24 AM
Posted 09 April 2007 - 09:26 PM
Posted 12 April 2007 - 10:18 AM
Posted 12 April 2007 - 10:43 AM
Posted 12 April 2007 - 10:54 AM
Posted 12 April 2007 - 09:20 PM
