Hi guys, I can't get my cylinder head off today for love nor money. I've disconnected everything, all bolts off and whatnot. But the head is sealed on fast. I don't have a mallet to hand as i've never had a cylinder head get stuck tight before, but i've tried levering between under the thermostat. I've tried tapping with a hammer (through a cloth/onto a piece of wood). But no joy. The only thing i can think of is because i haven't been able to take the studs out,only the bolts securing them. I tried to get them out but can't work out how to get leverage on them without damage. Any suggestions? I'd like to get this finished today, since I took the day off work!
Head stuck tight!
OllyD
, Mar 25 2007 12:39 PM
7 replies to this topic
Posted 25 March 2007 - 12:39 PM
Posted 25 March 2007 - 12:41 PM
I have the same problem! Just posted the same thing. Hopefully someone will help us out
Posted 25 March 2007 - 01:06 PM
to remove the stud, did u try tightening 2 nut against each other on the stud, then use them to unscrew that stud?
Posted 25 March 2007 - 01:18 PM
Not sure if its a good idea but if you have removed the rocker shaft you could try cranking the engine to blow the head off with compression. Disconnect the HT leads to the spark plugs first.
Edited by koss, 25 March 2007 - 01:20 PM.
Posted 25 March 2007 - 02:09 PM
Posted 25 March 2007 - 02:30 PM
Thanks guys. I did use the search engine, but the search engine on this site is a chocolate teapot, only allow exact phrase matches. Also, the topics i did find offered no successful solutions.
Anyway, i've managed to pull all but one stud using the two nut locking method. But the central stud is ,surprise surprise, siezed in place. I've tried rotate the head off, and got as faras the alternator (dragging it mercilessly over the bonnet lock mechanism, taking paintwork with it ), but it will go no further with the alternator and engine number in the way. Any further thoughts?
Posted 25 March 2007 - 03:42 PM
Try putting some releasing oil around the stud and leaving it to soak in. Then with a nut on top of the stud, try tapping it side to side with a small hammer to try and break its bond, adding more oil as you go.
Posted 25 March 2007 - 04:45 PM
Had a play around with mine today and managed to strip quite alot. But the head is still there!
I'm gonna buy a fence post, chop it in 3 to make a "U" frame. Put the engine on a brick, tie the head to the top of my "U" frame with some rope, remove the brick and let it hang on the head overnight with some WD40 on. Give it a jolly old smack in the morning and I hope it will come loose!
