such thing as a lower arm bush removing tool?
Posted 26 March 2007 - 07:31 PM
Cheers for your help,
jef
Posted 26 March 2007 - 08:11 PM
Edited by vasi, 26 March 2007 - 08:14 PM.
Posted 26 March 2007 - 11:18 PM
Find a socket that has an internal diameter bigger than the bush, but not as big as the bottom arm. Then place it flat against the bush with the hexagonal end inwards. Stick a big bolt through the socket and bush, and fit a nice chunky washer and a nut on the other end. Tighten it all up, and the bush will be pushed out of the arm and into the socket.
Difficult to describe this one, but its very simple to do, and i haven't been beaten yet...!!
Posted 26 March 2007 - 11:41 PM
Good luck
Posted 27 March 2007 - 06:38 AM
Posted 27 March 2007 - 07:46 AM
Posted 27 March 2007 - 07:55 AM
Jefinabox, are you talking about the front or rear suspension?
Edited by Flappyplasticbits, 27 March 2007 - 07:55 AM.
Posted 27 March 2007 - 08:04 AM
Posted 27 March 2007 - 03:00 PM
Posted 27 March 2007 - 03:06 PM
As Syholl has suggested, you can make a tool as described if needed.
Posted 28 March 2007 - 12:36 PM
But then i am an idiot!
Edited by AndyR, 28 March 2007 - 12:39 PM.
Posted 29 March 2007 - 05:45 PM
cheers for your advice, will let you know how it goes
