How many engine steady mounts should there be on an Automatic 998 and where are they located??
the engine makes the car rattle quite a lot and cowboy is currently under my Mini repacling 2 snapped exhaust mounts ( really nice for those to go one way home yesterday leaving the exhaust hangin).
Currently he says there is one, but i think there should be at least 2 since the vibrations can get pretty bad when idling.
hope someone can help us out here since we last replaced the exhaust brackets not that long ago
Engine Steady's
Sunshine
, Mar 31 2007 04:44 PM
2 replies to this topic
Posted 31 March 2007 - 04:44 PM
Posted 31 March 2007 - 05:09 PM
Mine only had one, so i fitted an ultimate engine steady on the other side. This helped a lot.
Posted 31 March 2007 - 09:42 PM
The Mini auto only has the one steady bar from the block to the master cylinder bracket. Fitting the poly bushes to it helps a lot, as does fitting an ultimate steady as mentioned above.
