Alternator Wiring
3 replies to this topic
#1 Guido
Guido
    Just On Tickover
  • 8 posts
Posted 01 April 2007 - 04:21 PM
Hi All,
Does any know which terminals I need to wire to the new alternator? I removed my original alternator which has a plug and three wires that I've taken out of the plug (2 fat and one thin).
The new alternator (70 amp orig 45 amp) has three terminals:
B+
D+
W+
Can provide a pic if this helps!!!
Cheers all.
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 01 April 2007 - 05:31 PM
Not a straight swap Lucas alternator then? Are you sure it turns the correct way?
#3 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 01 April 2007 - 07:36 PM
W+ : rev counter (usually on diesels)
B+ : Main output - normally connected directly to the positive terminal on starter solenoid. From there there should be a thick gauge cable to the positive terminal on the battery.
D+ charge light.
+ : small spade connector (if it has one) radio suppressor.
#4 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 03 April 2007 - 09:58 AM
anychance of a pic
it will help
