helllo you lot how hard is it to fit a 3 clock dash to a mini with a center clock ?? its a 1981 mini ?? any advice welcome thanks!
3 clock dash
MiniMadAdy
, Apr 01 2007 08:13 PM
3 replies to this topic
Posted 01 April 2007 - 08:13 PM
Posted 01 April 2007 - 08:20 PM
You will need a new speedo cable cable, then i think that you can just mount the different gauges.
Posted 01 April 2007 - 08:25 PM
yeah as tomf said youll need a new speedo cable a longer one ! i think
if you fitting it to a dash then it shud go straight in if not youll need the mounting brackets
you might also need the 2 connectos for the tacko
on the other hand you might not have the rectangle connector for the 3 clocks in your loom as you have a center cluster
im not sure
scotty
im not sure
scotty
Posted 01 April 2007 - 08:28 PM
Oh yea also if you have a center clock at the moment, im guessing you dont have a top dash rail, so you will have to make sure you have a dash that will fit without the top dash rail or just fit a top dash rail as well.
