errrm
Jordie
, Nov 02 2004 06:44 PM
15 replies to this topic
Posted 02 November 2004 - 06:44 PM
I have a JVC headunit (rated 4x 45w RMS) with a pair of magnet 6x9's (150w RMS each)
I have now bought a 10" Free air sub on ebay, and am currently bidding on a amp.
The sub specs:
10" Component Subwoofer ( Free-Air )
400 Watts Output
4 Ohm Impedance,
Frequency Response : 20 - 3,500 Hz,
Can Be Used in a Sealed or Ported Enclosure,
Sensitivity : 92 dB,
33 oz. Strontium Magnet
^^^^ COST £3.20 ^^^^WOOOOO ^^^^
And the amp, is a Longmill JL900 (cant find any specs, but has run 6x9's and a 440 sub according to ebay)
All i know is that,
2 Channel Amplifier
Usual bridging facility, with overload thermo protection, low and high level inputs, gain level control, treble and base. Visual led power and protection indicators.
High powered Amp, but not quite sure what out -put, but was running 6 x 9`s and a 440w sub.
So my question is, if i wire the amp to my Headunit, can i wire the 6x9s to the amp so i can get the fully 150w of the speakers aswell as my sub?
cheers,
Jordie
The sub specs:
400 Watts Output
4 Ohm Impedance,
All i know is that,
2 Channel Amplifier
cheers,
Jordie
Posted 02 November 2004 - 06:51 PM
no, with that amp u can either run ur 6x9s or the sub. i would possibly run both but not very well.
Posted 02 November 2004 - 06:52 PM
cheers. Should i keep the 6x9s direct from the headunit then and run the sub from the amp?
Posted 02 November 2004 - 07:14 PM
yeah that sounds like ur best bet.
sorry to hijack the post a bit but would i notice much difference if i got rid or my 10 inch sub in the boot and got a free-air 10 for the shelf?
rob
rob
Posted 02 November 2004 - 11:18 PM
mines for the boot. am gunna get a boot board and mount it to that.
U can get 2x 6x9 and a 8" in shelf i believe. Weakening the shelf tho....
Posted 03 November 2004 - 09:09 PM
got the amp for £12.
Posted 03 November 2004 - 10:10 PM
LOL bargain.
Posted 05 November 2004 - 10:55 PM
That sub was the first one I ever had and it's still a great sub.For £3.20,thats got to be the best buy I've seen.
Posted 06 November 2004 - 12:59 AM
it arrived this evening. wooo
Posted 06 November 2004 - 01:15 AM
lol whatever power that amp is, £12 quid is a bargain
just got back from bonfire night party...bit worse for weaar
Posted 06 November 2004 - 12:32 PM
your head uni isnt 4x 45 rms... the 45 watts is peak as are all the wattages given on head unit! yuo are looking at around 25 watts peak
Posted 06 November 2004 - 12:34 PM
thats a nice old skool sub too! just bridge the amp, and gradually turn it up untill the sub distords and durnt the gain on the amp down a tad!
Posted 06 November 2004 - 04:49 PM
yeah thats the plan. Just need to get me a wiring kit later in week and i can test it, aint fitting owt until i get a boot board.
...Means i'm gunna have to refit the airhorns
Posted 07 November 2004 - 12:08 AM
good luck
Posted 07 November 2004 - 12:41 AM
if you are running the 6x9's from the headunit then you need a crossover to block out frequencies less than 70hertz, you can sometimes do this from the headunit or you can buy in line filters which block out the really low frequencies.
The reason for this is with the volume cranked up you won't be able to hear the 6x9's distorting for the bass from the sub, also you will get a cleaner sound and be able to give it more volume and you're 6x9's will last a sight longer.
