The engine was running OK, but overfuelling badly judging by the sooty black tailpipe and plugs and atrocious fuel consumption (15-20mpg!). I wasn't able to sort this by leaning off the mixture (turning the adjustment screw on the base of the carb on the drivers side clockwise/inwards) and was fed up with the noisy operation of the electronic fuel pump, so changed it for a mechanical one in an effort to solve both problems.
Fuel pump is now silent, fuel consumption is now about 50% of what it was and after the first drive yesterday the tailpipe was almost clear of soot. Job done, I thought, but Mini has other ideas.
During a second drive last night, the car developed a slight misfire on the overrun. Checked all vacuum hoses, plug leads etc, can't find anything obviously wrong. Drove the car again this morning and found that the misfire is much worse when the engine is cold. Once the choke is fully in it still misfires ever so slightly on overrun, but it's much less pronounced. There doesn't seem to be any misfire under load (unless it's so slight I'm not noticing), only on the overrun.
What am I seeing here? Based on the adjustments made I'd have said mixture too lean / fuel starvation, but the tailpipe is now as sooty as before which seems to contradict that. If running too lean I'm told you'd also expect the engine to run hot, but water temperature at least has shown no change - it still sits on the halfway mark at all times.
I wondered if the dashpot oil might be low, but it seems OK.
Stumped again - any ideas please?
Edited by whawes, 23 April 2007 - 09:04 AM.
