There have been a few post about mentioning people with alarms that when unlocking the car from the key fob, lower the window so that there is no need to have door handles. Does anyone know what alarms have this feature as when I get round to fitting my lightweight doors i wanted to leave them without handles.
Matt
Alarms
Kustom
, Nov 08 2004 12:43 AM
7 replies to this topic
Posted 08 November 2004 - 12:43 AM
Posted 08 November 2004 - 08:10 PM
It might be a bit tricky to fit all that gear inside a Mini door, they're quite thin.
Posted 08 November 2004 - 08:12 PM
it is possible. a company called Python Alarms makes the right kit im sure...
its hard work getting it all set up though, weighty too
Posted 08 November 2004 - 09:38 PM
wouldnt have thought it was that heavy the only parts in the door would be the central locking actuator, the electric window kit and the main weight being the glass window. All the rest would be electronically controlled by the alarm at some other position in the car.
Posted 08 November 2004 - 10:44 PM
there is a solenoid to release the door, then there is the window motor which weighs a reasonable bit, but if your after comfort and performance, weight is not going to be of critical value to you.
Posted 09 November 2004 - 08:27 AM
I dont want a solinoild to open the door, just a cenreal locking motor to unlock it, the window then winds down and the door is opened via the inside handle.
On the topic of reduce weight your right its not my main concern but that doesnt mean i want to go adding weight on.
I was under the impression that the electric window kit weighed less than the winder mechanism, this is deff. the case with other cars maybe not the mini.
Matt
Matt
Posted 10 November 2004 - 11:04 AM
ah yes now i understand. opening the door from the inside...
sounds good, let us know if u pull it off.
Posted 11 November 2004 - 03:21 PM
electrical window winder mechinish is heavier than the mechanical one. The mechanical one is pritty light and very simple just stamped ally
