Suspension
Posted 24 April 2007 - 07:50 PM
Any advice/info on this grate full, can be fairly technical as i'm a full time defense aerospace engineer lol!
Posted 24 April 2007 - 07:54 PM
Edit: sorry, where's my manners. Welcome to TMF
Edited by DJH MINI MOTORSPORT, 24 April 2007 - 07:55 PM.
Posted 24 April 2007 - 08:39 PM
The 1st step would probably be to replace the dampers for adjustable items and swap the suspension bushes for stiffer polyurethane ones.
Ideally an adjustable set-up would be the way to go, with adjustable tie bars,front lower arms and rear negative camber brackets:-
http://http://www.mi....aspx?pid=38461
http://www.minisport...it-product.html
Then you could always lower the car but then you have to buy different dampers and it all depends on what size wheel/tyre combo you're using too!
How long's a piece of string???!!!
Posted 24 April 2007 - 09:47 PM
Im running 13x7's on my mini rio and its goinf to be used for normal road use
Posted 25 April 2007 - 08:35 AM
adjustable suspension? coil overs? and what exactly are hi-lows?
Adjustable shocks, you already have adjustable tie bars & I assume your camber brackets are adjustable (?)
Hi-lo's allow you to adjust the ride height of the car, which is pretty much a must imo
Posted 25 April 2007 - 09:30 AM
http://www.minispare....aspx?pid=37151
http://www.minisport...em-product.html
They replace the alloy suspension trumpets and allow the ride height to be adjusted. To install the front ones though will need a cone spring compressing tool. The rears are straightforward enough to install though.
I'd say this is a must for your particular set up, seeing as you already have adjustable elements in your suspension. You also didn't say if you had adjustable dampers fitted?
Then of course get the whole alignment set up correctly and the handling should be transformed.
Posted 25 April 2007 - 10:30 AM
Posted 25 April 2007 - 10:41 AM
i was thinking rear beam myself but where does it all stop?????!!!!!!!
Posted 25 April 2007 - 10:50 AM
see that's the trouble with posting on here.............there's no telling where it'll end up!
I had a rusty subframe and a good second hand one at a scrappy was £85..... I have 13 X 8 on the back with 205/50 dunlops which were touching the radius arm bracket a little when the car was jacke up.... the rear beam moved the wheel back in the arch a bit so i had to fettle the back out and the inner arches are being "tubbed" as the coils were catching a bit.... also my front sub is being altered to allow it to run lower.. i have tiny 13 X7 on the front with 195/45 dulops.
All in all, it should hopefully mean that i never have to change a rear subframe again, nor worry about changing cones.... Car is too low to get on the rolling road now though.... were going to try and lift it on
Posted 25 April 2007 - 12:06 PM
Posted 26 April 2007 - 10:23 AM
or.... just get rid of the ruber cones and get some coil overs... you can then get rid of your rusty rear subframe and get a nice rear beam!!!!!!! mmmmm
More hassle than it's worth if you ask me
Posted 26 April 2007 - 05:43 PM
If you find that your rubber springs/donuts have sagged or collapsed then it's worth fitting replacements and Mini Spares are probably the best place to get them from since they stock genuine O/E Moulton/Dunlop types. Cheap after-market copies have been known to collapse in no time.
With the Mini Sport Adjusta-Ride kit you also get new knuckle joints and cups too and that's something you generally don't get with Hi-los. At least I don't think so anyway?
Edited by taffy1967, 26 April 2007 - 05:48 PM.
Posted 02 May 2007 - 09:57 PM
Posted 02 May 2007 - 10:18 PM
Posted 03 May 2007 - 02:59 PM
And if uv got fully adjustable suspension (far from standard, we all wish it was) then get evrythig set up rite, camber, castor, toe in/out
Edited by Scarface, 03 May 2007 - 03:03 PM.
