Angle Grinder 1 - Flywheel Nil
18 replies to this topic
#1 zomerzet
zomerzet
  • 233 posts
Posted 25 April 2007 - 11:31 AM
Bought myself a nice low milage metro engine from ebay and the time came to make use of it so tried getting flywheel off with puller and it decided to strip the thread of one of the 3 bolts. re-tapped it tried again, same problem. Re-tapped larger, ditto. Was told to get a flywheel off that's this stuck is to chop of the starter housing and :lol: it with a full on sledgehammer! Didn't fancy that so invested in a lovely new angle grinder to chop the old flywheel off!
Below is the result! I did manage to cut into the crank slightly on two sides but there is more than enough material to provide a good base for the flywheel to sit over. New block, here we come!
Attached File  J4100013.jpg   93.43K   45 downloads
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 25 April 2007 - 11:34 AM
Great googly moogly.
Thats the way to do it.
#3 TOMMO0302
TOMMO0302
  • 1,688 posts
Posted 25 April 2007 - 11:41 AM
Ooer, you got a pic of the crank?
#4 *DJH*
*DJH*
  • 4,972 posts
Posted 25 April 2007 - 11:48 AM
Bought myself a nice low milage metro engine from ebay and the time came to make use of it so tried getting flywheel off with puller and it decided to strip the thread of one of the 3 bolts. re-tapped it tried again, same problem. Re-tapped larger, ditto. Was told to get a flywheel off that's this stuck is to chop of the starter housing and :) it with a full on sledgehammer! Didn't fancy that so invested in a lovely new angle grinder to chop the old flywheel off!
Congratulations on your first serious bodge :ermm: i'm proud of you :lol:
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 April 2007 - 11:57 AM
Only ever had to do it once, and cut a single slot and then stuck a cold chiesel down it to split it open....
#6 Natalie
Natalie
  • 1,956 posts
Posted 25 April 2007 - 12:55 PM
Ah but does your dipstick stay put :lol:
#7 *DJH*
*DJH*
  • 4,972 posts
Posted 25 April 2007 - 01:21 PM
:ermm:
#8 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 25 April 2007 - 01:56 PM
ahahha, ive been there before.. funnily enough that was also a metro engine.
#9 zomerzet
zomerzet
  • 233 posts
Posted 25 April 2007 - 02:56 PM
Yes the crank is chafed as they say but as long as I torque and re-torque the flywheel several times when refitting I shouldn't have to worry about it slipping at all, I don't reckon.. :s It looks worse on the pic than it actually is. I couldn't get my angle grinder at the right angle to do the one slot so sliced it top and bottom doing my best to avoid the crank.
Attached File  J4100010.jpg   116.2K   72 downloads
The dipstick won't need restraining once this block is fitted as it's fine. At the moment, the pressure that should be pushing my piston down is escaping past it and pressurizing my oil slightly :lol:
#10 thedaz101
thedaz101
  • 65 posts
Posted 25 April 2007 - 03:22 PM
woot one lighten flywheel sell that on fleabay
#11 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 25 April 2007 - 03:27 PM
that crank is scrap end off
dave
#12 Udo
Udo
  • 1,670 posts
Posted 25 April 2007 - 05:29 PM
I have to agree with Minidaves zomerzet
Maybe some closer up pictures of the crank tail?
#13 Silicon Skum
Silicon Skum
  • 741 posts
Posted 25 April 2007 - 06:56 PM
While engines are not my strongest point, I do know a little about mechanical things - and I REALLY doubt that crank is of any further use! Maybe a nice door stop...?
The crank is no longer true so there will be increased loading on the rest of the crank area, and unbalanced loading of the flywheel mating surface material, which will lead to probable increased wear and movement - and a very early failure of the crank / flywheel! :ermm:
Bin it and stick a new / recon crank in there. The engine is out and part stripped, so you might as well do a proper job NOW, rather than wait for something to fail and have to rebuild the engine anyway. :lol:
SS
#14 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 April 2007 - 07:35 PM
That's a big oops....
Bye bye crank....
#15 Jammy
Jammy
  • 25,397 posts
Posted 26 April 2007 - 09:15 AM
If you need a new crank, lol, sorry, well you do need a new crank... anyway, I have one you could buy.
