hi, i need a new distributor for my 1973 1275gt, the one on it is a 25d, which other distributors will work with this engine? thanks
which distributor can i use?
bennivory
, Apr 29 2007 10:44 AM
3 replies to this topic
Posted 29 April 2007 - 10:44 AM
Posted 29 April 2007 - 05:11 PM
Posted 29 April 2007 - 11:36 PM
What will fit and what's best for your engine are different matters. Any DM2, 23D4, 25D4, 45D4 (and probably others) will fit. Virtually any 4-cylinder Lucas distributor for the A- or B-series engines (not A+) will fit and will work. However, which advance curve is best for your engine can only be determined by dyno tuning. Since this is for a 1275GT, you could consider the 23D4 (centrifugal advance only) dizzy from the Cooper-S. Is it right? Who's to say? If you're using this as a street car, a 25D4 or 45D4 with vacuum and centrifugal advance would probably give you better fuel economy and reasonable performance (look for something out of a mid-1970s MG Midget before the switch to the 1500 engine). After that you open up the door to aftermarket dizzys... all of which will cost more than a good, used Lucas unit.
Posted 30 April 2007 - 05:35 PM
thanks very much mate, thats very informative, cheers
