OOOOOOOOOOOoooOOOO A Shiney new 'Push Start' Button for turk!
#16
Posted 30 April 2007 - 03:03 PM
#17
Posted 30 April 2007 - 03:04 PM
MK3's should have a steering lock...
Maybe FREAK is more of a freak than you first thought... with MK2 bits
She am de FReaKiest!
Dunno, unless earlier MK3's were different to later ones? She's got a magic wand plate and did have a remote gearbox too. All of the switches (well, the two of em) are in the centre, along with the ignition barrel.
Perhaps Ze FReaK has been tweaked.
Hang on, I've really hi-jacked this thread. I apologise!
#18
Posted 30 April 2007 - 05:03 PM
#19
Posted 30 April 2007 - 05:06 PM
mmmmmmm think you wil find that that is a Triumph Spitfire starter button & not off a Spitfire plane if that is what you were thinking.You call that a starter button? This is a starter button!
http://cgi.ebay.co.u...1QQcmdZViewItem
Alan...
#20
Posted 30 April 2007 - 05:09 PM
#21
Posted 30 April 2007 - 05:10 PM
Ryan
#22
Posted 30 April 2007 - 10:41 PM
Sparked Quite a debate here!
I had a chat with my mate today and he said B*ll*cks. So now i'm even more confused!?!
Its still seems strange not using a key!! I always go to take it out.....
#23
Posted 01 May 2007 - 12:24 AM
This:
Item 1) Anti theft device.
In addition to the normal ignition switch the vehicle must be permanently fitted with a device to prevent the vehicle being driven or moved under its own power. This device should NOT operate on a part of the braking system and cannot be activated with the engine running. Nor can the engine be started without the device having been deactivated and its operation must be distinct and separate from stopping the engine..
The basic interpretation is that a column with a steering lock will do the job or anything else that only activates when the key is removed rather than just turning the engine off ie immobilisers where the key is the final coded link. It is also possible that a ‘credit card ‘ type pre ignition circuit immobiliser would meet this criteria meaning a steering lock would not have to be fitted.
A key operated battery kill switch should also be ok.
is the version of the same regulation and some interpretation of it from the SVA test. Assuming that the law from the regs is the same (which is a big assumption) it seems that you could be OK if you fit a Dis-car-nect type device in the boot. I would avoid one of the FIA type plastic key switch devices for reasons of reliability that I have mentioned in other threads.
For the moment that seems to be the closest to the truth that I can get. I will have another go tomorrow.
#24
Posted 01 May 2007 - 09:00 AM
Well, I did have, til I sold the car!
#25
Posted 01 May 2007 - 09:28 AM
#26
Posted 01 May 2007 - 09:47 AM
#27
Posted 01 May 2007 - 10:59 AM
#28
Posted 01 May 2007 - 01:54 PM
#29
Posted 01 May 2007 - 04:08 PM
#30
Posted 01 May 2007 - 06:05 PM
Its great to have a person such as yourself on a busy forum to dig deeper into questions. Nice one!
Push starts are ace!
