Hi all going to post some updates soon, just making my dash at the mo but have a couple of questions some of you may be able to help with.Firstly have had a rev counter made to suit me haybusa engine- it has + and - for power and w terminal for the pickup-anyone know where to connect at the engine end? And secondly wanting to fit an electric oil pressure gauge in line with the oil pressure sender, does anyone know what the thread size is on the standard suzuki oil pressure sender? Any help would be greatly appreciated
many thanks oli
Dash wiring help needed
oli79
, Apr 30 2007 10:07 PM
2 replies to this topic
Posted 30 April 2007 - 10:07 PM
Posted 01 May 2007 - 02:59 PM
sorry Oli, i did mean to reply to your PM, I dont know the thread as i used an adaptor from westfield to plumb in an ancilliary gauge.
As for the wiring output i used the Yellow/blue wire and set the tacho to 2 cylinders as it will show at 1/2 speed otherwise, something i took a while to sort out as i thought STACK Tacho was faulty at the time.
Posted 01 May 2007 - 05:28 PM
Dont worry mark i know everyone is very busy at the mo,wasnt in any rush, just thought i would post as well to see what everyone came up with as i know you are all a knowledable lot. Apart from that youve told me all i need to know for the moment so once again many thanks for the help- going to get spannering now -ta oli
Edited by oli79, 01 May 2007 - 05:35 PM.
