not quite sure which mounts actually need changing for a flipfront!
mic
do i ned compression tool to change subby mounts?
mic
, May 03 2007 01:43 PM
3 replies to this topic
Posted 03 May 2007 - 01:43 PM
Posted 03 May 2007 - 01:52 PM
Rear front and tower mounts need to be solid mounts, not poly or rubber.
Posted 03 May 2007 - 01:56 PM
Yar, as Adam has said, replace the tower bolt bushes with solid ones and also the floor mount ones.
No suspension cone compression needed on this job, the cones stay in the subby as you lower it to change the bushes. Be careful as you lower it to change them, just make sure you're not overstressing/stretching any cables, pipes etc.
Posted 03 May 2007 - 02:10 PM
You don't need on to do that unless you changeing your cones but if you need on I have on ein the garage depending where about you are in Berks.
Edited by Road Runner, 03 May 2007 - 02:12 PM.
