Knocking Sound
8 replies to this topic
#1 CooperTrooper
CooperTrooper
  • 1,192 posts
Posted 08 May 2007 - 07:37 AM
Hi, iv recently had a reconditioned gearbox put in my car with a new spi clutch kit and its been running fine for about a month now, however this week, i have noticed a 'Knock' sound when i bring my foot off the clutch pedal .. or when i take the pressure of my accelerator pedal.. i hear a single KNOCK sound. Any ideas what this could be?
#2 minislapper
minislapper
  • 1,957 posts
Posted 08 May 2007 - 07:40 AM
Engine steady bushes first thing to check. Get someone to rev the engine and see if the engine moves. Or simply try to rock the engine. Did the garage put new engine/gearbox mounts on when they replaced the clutch?
#3 CooperTrooper
CooperTrooper
  • 1,192 posts
Posted 08 May 2007 - 08:19 AM
Im not sure if they did or not, i got all the work done at minisport a month or so back - iv got the receipt so ill check if they have on there. I dont think they did to be honest... iv got a fairly recent 98 mpi so would the bushes need changing?? Ill try the engine rev when i get back from work.
Edited by CooperTrooper, 08 May 2007 - 08:21 AM.
#4 Dev
Dev
    Fiat 500 'Ringer
  • 1,549 posts
  • Local Club: NF500
Posted 21 May 2007 - 01:13 PM
Giles,
If you buy the bits you need for your engine i'll have a look at this and fit them for you.
Let me know
#5 Jammy
Jammy
  • 25,397 posts
Posted 21 May 2007 - 01:30 PM
Well those bushes will be nearly 10 years old now! So it would make sense to change them anyway, its not too hard with a carb mini, not sure how hard it is with all the MPi gubbins in the way.
The other option could be the clutch release bearing, although I would be surprised (and shocked at MiniSports work) if it is this.
#6 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 21 May 2007 - 03:24 PM
It could also be the manifold/downpipe striking the bulkhead that's making the noise.
So you should ensure that the downpipe is properly secured to the gearbox via the little bracket on the rear side, otherwise you could end up with a fractured downpipe and blowing manifold.
Perhaps the bolt that secures it has fallen out or was never refitted? I'd get it checked now to be sure.
#7 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 21 May 2007 - 04:59 PM
I have this problem at the moment. Will likely be subframe rubbers worn out.
#8 rgo
rgo
  • 33 posts
Posted 28 May 2007 - 04:16 PM
Hi,
Just went through reading this and I have a similar problem but it knocks more than just once when I take my foot off the accelerator pedal rapidly
and seems to do the same sometimes when rapidly accelerating. Would my problem be similar to CooperTrooper?? :lol:
#9 jonny d
jonny d
  • 1,148 posts
Posted 28 May 2007 - 08:24 PM
yeah check the easy bits first top steady bushes change to poly bushes should cure it.
