what do you do for the front driveshafts as they arnt long enough to meet in the middle? ( not that it make a difference if they did i suppose)
do i assume you have 1 long one made up from...... somewhere?
cheers
mic
front driveshafts
mic
, May 09 2007 04:34 PM
3 replies to this topic
Posted 09 May 2007 - 04:34 PM
Posted 09 May 2007 - 07:18 PM
Why? If the engine is in the rear you just remove the driveshafts and leave the outer CVs.
Posted 09 May 2007 - 09:15 PM
Well I done what rover did when they built the MGF. Just hollowed out the cv joint.
Mounted the magnets for the speedo on the outside of the cv. Worked fine.
They are pretty hard to machine unless they are annealed then re hardened.
