clutch probs
Posted 09 May 2007 - 05:26 PM
the clutch has done this before slipped then been ok, could it be the fact were ive had my foot on the clutch then ridin the clutch in traffic
Posted 09 May 2007 - 06:47 PM
Posted 10 May 2007 - 11:34 AM
Posted 10 May 2007 - 11:49 AM
found that there is oil coming out of the split pin at the base of the housing which indicates oil contamination is it poss to spray clutch cleaner into the two hole in the top of the housing to clean the oil out
this has happened to me before, it sounds like your crank seal on the clutch side has blown, only way to sort that is to have the whole lot off and put a new one in
Posted 10 May 2007 - 11:57 AM
Posted 10 May 2007 - 02:32 PM
Ive been noticing my clutch pedal is VERY stiff when changing 1st to 2nd gear...every other gear seems okay, also after starting when changing inton a gear even if I make sure the clucth is fully in the gears sometimes crunch....Ive checked the fluid and that is fine...!?Help
Posted 13 May 2007 - 10:05 PM
how hard is it to do the seal and what do you have to do
ok well I don’t now rely how hard it is with the engine in the car because i took mine out but im told you have to undo the engine mounts and jack ou the clutch side of the engine, then basically all you have to do is as follows:-
1. take the housing off 12 bolts i think? (shouldn’t be too bad in there asbestos wise because of the oil but id still where gloves)
2. get the flywheel puller, line it up and then tighten the centre bolt, smack the puller with a hammer and stand clear, the flywheel + clutch should fall off
3. pull the dust cover off the seal, then remove the seal
4. remove the spine from the crank, or if your very careful slide the new seal over it, I don’t recommend this though
5. add the new seal in, if its in the wrong way it will not go all the way in as I found out.
6. and then do the reverse of above, make sure your replace the clutch whilst you are in there, saves you having problems with the old 1
if you want to have a look at some of my engine rebuild it is on the link bellow:-
http://www.theminifo...showtopic=32802
edit* added
forgot to say this is for the verto type engine setup
Edited by minimad998, 13 May 2007 - 10:07 PM.
Posted 13 May 2007 - 10:10 PM
Karls Clutch...
hi karl, im not sure what your problem is but i would start by either checking the clutch arm making sure that it is free moving, as they tend to seize up a bit, and also the clutch adjuster, hope this helps
Posted 13 May 2007 - 10:13 PM
Posted 13 May 2007 - 10:23 PM
Okay thankyou, is that all rather accessible, or does it involve taking the clutch apart?
ok here is a picci of the areas that the clutch is on soz for got to say the glywheel goes on then the clutch on the spline and then the pressure plate and hub assembally ive got some pics bellow to help you visulise it
clutch.JPG 239.88K
15 downloadsif you need anymore help let me now
edit*
oh and i have labelled a 1 on the area where the clutch comes into contact on the flywheel and pressure plate
Edited by minimad998, 13 May 2007 - 10:25 PM.
