When doing a turbo conversion, what clutch master cylinder do you use? Also when you upgrade to 4 pots, with servo do you need to upgrade the brake master cylinder?
Master Cylinder's
Turbo Tom
, May 09 2007 06:05 PM
1 reply to this topic
Posted 09 May 2007 - 06:05 PM
Posted 13 May 2007 - 11:18 PM
i thought there was only 1 sort of clutch master cylinder? well, there's a tin or plastic one but both are the same afaik.
if its the combined master/servo then you can't change it, the only thing you may need to change is the rear wheel cylinders.
