what rockers
9 replies to this topic
#1 backstreetclassics
backstreetclassics
    Previously known as minidan07
  • 1,898 posts
  • Local Club: essex mini club
Posted 10 May 2007 - 07:42 PM
hi i have a 998 with uprated cam shaft inch and half carb what roller rockers would go best with this type of spec ??
cheers dan :w00t:
#2 benpopham
benpopham
    The Carbon Weezel
  • 1,149 posts
Posted 10 May 2007 - 07:45 PM
hey i have a heavily modified small bore and im still running standard rockers.. they are fine for the job.
but if your desperate.. go for some 1.5's
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 10 May 2007 - 07:54 PM
NO!
NOT 1.5! They give too much overlap. You'll loose a few BHP. For a Small bore engine all you need AT MOST is 1.3 standard rockers are 1.25-1.3 so there's not much point.
If you really want you can spend £100+ on 1.3 roller rockers. Or get some diffrent standard ones, the pressed steel ones are nice. But over all rocker is a rocker is a rocker.
ROCKER!
#4 backstreetclassics
backstreetclassics
  • 1,898 posts
Posted 10 May 2007 - 07:57 PM
so what yr saying is save my money and just put some standerd 13300 rockers on there
#5 Big_Adam
Big_Adam
  • 7,435 posts
Posted 10 May 2007 - 08:00 PM
Standard will do the job, if your REALLY trying to squeeze every last wee bhp from the engine (race stuff) then go for 1.3 roller tipped. Should reduce valve wear and side loading a little.
If not save your cash.
#6 backstreetclassics
backstreetclassics
  • 1,898 posts
Posted 10 May 2007 - 08:01 PM
thanks 4 the advice
#7 Big_Adam
Big_Adam
  • 7,435 posts
Posted 10 May 2007 - 08:08 PM
It was my pleasure.
*goes back to reading vizard books to look smart*
Edited by Big_Adam, 10 May 2007 - 08:08 PM.
#8 backstreetclassics
backstreetclassics
  • 1,898 posts
Posted 10 May 2007 - 08:16 PM
lol
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 May 2007 - 10:09 PM
Yes, the standard sintered rockers your engine was born with are fairly good. If you want to push the boat out get some repro 1.3 forged Cooper S rockers from Mini Spares which are excellent, IMHO rollers are not really worth it and as Adam says any ratio above 1.3 is wasted on most small bore engines. If you want to make a real difference for little cost, change the rocker shaft. This is a very easily overlooked component but the standard item can be fairly flexible, especially when worn. If it flexes in use, the valves don't open as far and they rock about in their guides causing excess wear to them. Thickwall shafts are a very good upgrade to consider.
You understand that no-one is saying use rockers from a 1275 here right? You seemed to say something about a 1300 above but we are saying 1.3 as that's the rocker ratio not the engine size. All late model rockers are the same, whatever the engine size.
Edited by Dan, 10 May 2007 - 10:09 PM.
#10 Yeti
Yeti
  • 225 posts
  • Local Club: I don't play well with others
Posted 10 May 2007 - 11:01 PM
I was going to say what Big_Adam said. I am also a disciple of David Vizard...... :w00t:
1.5 is to much for 998 and the money is better spent else where as regard to roller 1.3's (my personal opinion!.... Im looking at suck through turbos.... O_O have no money though....)
Mr Benn
