Needle Removal
Posted 13 May 2007 - 10:36 AM
Took the piston out etc, and removed the grub screw that i thought held the needle in, and the needle didnt pop out like i wasexpecting, am i missing something?
and also, messing about with this lovely precision bit of kit is a bit daunting, how hard are the mods described in the book? and how easy is it to mess up?
Posted 13 May 2007 - 10:41 AM
Might need to gove the needle a slight yank to get it out. SHOULD NOT take alot of force.
As for the mods, half the spindle. Don't bother with all this filing C**p. Just cut half the spindle (the not tapped half) off the side width as the valve.
Posted 13 May 2007 - 01:01 PM
so the only mod you would do is the halving the spindle.
you got any pics of your carb?
cheers big adam
Posted 13 May 2007 - 08:01 PM
Back in a bit.
[attachment=32777:P1010161.JPG][attachment=32776:P1010160.JPG][attachment=32775:
1010159.JPG]
and now showing off
[attachment=32778:P1010166.JPG]
Edited by Big_Adam, 13 May 2007 - 08:17 PM.
Posted 13 May 2007 - 08:19 PM
Posted 14 May 2007 - 02:34 AM
Posted 14 May 2007 - 05:04 AM
not sure what you are getting at?
Posted 14 May 2007 - 12:09 PM
Loctite comes in multiple grades and while the base may be similar to super glue, the amount and type of filler greatly changes its properties. Most Loctite small fastener grades are "softer" than super glue (they have lower sheer strength). The grade numbers Heinkle/Loctite uses in Europe are different than in the U.S. so it wouldn't make sense to name the grades I use. Suffice it to say that they have a grade recommended for removable fasteners smaller than 6mm (usually purple in color) and a grade for 6mm and larger (usually blue in color). There are permanent grades for use across the board, most of which are red in color. All of these allow more generous assembly time and are generally more removable than super glue.
Posted 14 May 2007 - 12:24 PM
I used it to hold my numberplate bolts on.........I had to cut them off when I smashed the plate.
Posted 14 May 2007 - 02:10 PM
Yes and no.
yes i knew as soon as posted that you would say this.
my bad i forgot to mention the different grades
