suspension setup problems
20 replies to this topic
#1 Gizzum
Gizzum
  • 554 posts
  • Local Club: None atm
Posted 14 May 2007 - 11:37 AM
Guys n gals...
Just got my shiney starmags fitted to the car finally!
The problem I now have is that, they did the tracking and gave me a sheet of angles:
Primary angles...
Front camber left: 0.06 degrees
Front camber right: 1.18 degrees
front toe left: -0.6 degrees
front toe right: -0.6 degrees
rear camber left: -0.12 degrees
rear camber right: 1.36 degrees
rear toe left: 6.8 degrees
rear toe right: -0.3 degrees
thrust angle: 0.35 degrees
Secondary angles...
setback front: -14mm
setback rear: 2mm
track width diff: 44mm
wheel base diff: -16mm
What the heck is going an with my wheels, they seem to be pointing all over the shop! Can somebody please shed some light on these figures for me please.
Thanks in advance for your help!
Jez
#2 *DJH*
*DJH*
  • 4,972 posts
Posted 14 May 2007 - 12:05 PM
You need to get that setup properly! by a proper garage
#3 Gizzum
Gizzum
  • 554 posts
Posted 14 May 2007 - 12:37 PM
That's all well and good but i have all standard suspension. Am I going to need a full adjustable setup? i can get the camber and adjuster plates for the rear, but what will i need to get buy to get this setup properly??
Not got alot of wedge ATM so what is the bare basic to get this sorted???
#4 *DJH*
*DJH*
  • 4,972 posts
Posted 14 May 2007 - 12:39 PM
O.k. for starters, what were your wheel size and what are they now?
and having a standard suspension means nothing, the reason why this little lot is out will be due to worn components and/or wheel size if it's not standard.
#5 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 14 May 2007 - 12:42 PM
I had exactly the same with mine. Most standard setups are miles off what the factory specified due to wear and knocks and bent parts.The only way to get everything set properly is to go fully ajustable.
#6 Gizzum
Gizzum
  • 554 posts
Posted 14 May 2007 - 12:59 PM
o.k. then lets go for it...
was on standard 12's, no got 7.5 cooper s discs and flanges...
now running on 10 x 6 starmags on yoko's a008's (yeah).
would this solve the problem??
fully adjustable setup
I had replaced the nearside rear radius arm when i did a lot of work onthe car bout a month ago and it seems to be that side that is way out!! could it be a dodgy radius arm???
#7 Retro_10s
Retro_10s
    Moderator
  • 10,186 posts
Posted 14 May 2007 - 01:00 PM
oooh 6x10 starmags. I can't stand star mags usually, but 10's look good.
#8 Gizzum
Gizzum
  • 554 posts
Posted 14 May 2007 - 01:02 PM
Cheers Retro,
I really like the way they have come out... now to get some arches... after i've sorted out this bloody geometry out! was hoping to get meself a new sw5 07 but now looks like suspension stuff!
#9 biggav
biggav
  • 5,830 posts
  • Local Club: South Central
Posted 14 May 2007 - 01:07 PM
no point in havin a lairy cam if you can't keep it on the road!!!!! mine is soo much more fun to drive since i had the geometry and suspension done, its a whole new car!!!!
#10 *DJH*
*DJH*
  • 4,972 posts
Posted 14 May 2007 - 01:10 PM
Yeah that kit will help, but you need to do other checks such as mounts, bushes, bearings e.t.c.
#11 *DJH*
*DJH*
  • 4,972 posts
Posted 14 May 2007 - 01:11 PM
Holy repost batman!
Edited by DJH MINI MOTORSPORT, 14 May 2007 - 01:11 PM.
#12 Gizzum
Gizzum
  • 554 posts
Posted 14 May 2007 - 01:15 PM
DJH...
I know the rear bushes are o.k. as I replaced them bout a year ago. The rear bearings are o.k. as i had reaplced the nearside radius arm with a new one and there is no play in the offside. There is a slight wobble on front offside but nearside front is o.k. It seems that.. looking at the rear nearside that it is way out or is it me???
#13 *DJH*
*DJH*
  • 4,972 posts
Posted 14 May 2007 - 01:17 PM
Mine toes in like that, but it looks a bit more excessive. and as for that wobble, definately get it changed.
#14 Gizzum
Gizzum
  • 554 posts
Posted 14 May 2007 - 01:21 PM
Bugger it...
that kit plus bearing now on order!!!
the cam is gonna have to wait!!!
and the hi los....
and the arches!
ohh the pain!!
DJH... what repost!! :ph34r: :) ;)
I can see another how to guide coming on!!!
O.k. then so what should it be??
Edited by Gizzum, 14 May 2007 - 01:23 PM.
#15 *DJH*
*DJH*
  • 4,972 posts
Posted 14 May 2007 - 01:24 PM
I hit the reply button twice by accident :)
