Can anyone tell me the number of teeth on the primary and motion gear so I can check I have the right set before I bolt the engine together. I beleive it is 1.1 ratio and there is no groove machined in the gear if that is clear and I have been told the idler gear is common to all ratios any help anyone. It is a 1275cc a+
Drop gears
Maxmini
, May 15 2007 06:29 AM
3 replies to this topic
Posted 15 May 2007 - 06:29 AM
Posted 15 May 2007 - 06:56 AM
What no on on your forum know the answer. Would have though it easy to count them on the one you have. I can coun't them for you later if no one has answered.
Posted 15 May 2007 - 07:20 AM
As long as they are the same on both the input and primary gears it'll be 1:1 ratio, the number of teeth on the idler is irrelavent..
If it's A+ helical, then the number of teeth is 29
A series 24
SC the std 1:1 setup is 23 teeth
A series 24
Posted 15 May 2007 - 10:06 PM
Thanks Guessworks, I have counted 29 teeth on each. The idler gear is shimmed and I am ready for the rebuild tomorrow.
