can anyone help me wire this up. i think its wrong as its not turning.
the starter is by the inner wing the battery cable is the engine side
many thanks
t
solenoid
t@z
, May 15 2007 10:04 PM
5 replies to this topic
Posted 15 May 2007 - 10:04 PM
Posted 16 May 2007 - 07:59 AM
i know i probably asked this a bit late. i think all the brown wires need to go on the engine side, there are 3 of them one ring clip the other 2 are push clips, the red/white wire is correct. are the battery and starter the right way round?
currenty the solenoid clicks, the starter (tested) is smooth and the engine turns over easily enough (when just hooked up to the battery to starter) its just when its all in one circuit it doesn't do a thing.
i've put new earths on the engine as you can see in the pic below the solenoid and i replaced the battery boot earth?
Edited by t@z, 16 May 2007 - 08:06 AM.
Posted 16 May 2007 - 08:06 AM
I know this may be obvious but is the battery fully charged
Posted 16 May 2007 - 08:34 AM
yep, seem'd to get run down pretty quick but that could be to using a lot of current if the wiring isn't correct?I know this may be obvious but is the battery fully charged
however i dont know if its wired up right, really doing my head in.
the battery is only about 6 months old.
Regards
Chris
Posted 16 May 2007 - 05:46 PM
hi, sorry me again, i am at the car and have my solenoid wired up as shown
http://www.turbomini...p...&tid=143624
however when i have it like this i get live feeds to the dash without even turning the key?
also it clicks but still notturning over.
were a bit confused
anyone help
T
were a bit confused
anyone help
T
Posted 18 May 2007 - 09:30 AM
Try shorting the solinoid so that you get the live from the battery going straight to the starter motor cable. This way you can test if its the battery or not by cutting out the solinoid.
