starter motor query
Posted 16 May 2007 - 07:48 PM
There is no starter with it so am i right in assuming i need an inertia starter . Can anyone please clarify . and if so can the flywheel be adapted to take a pre-engaged starter. Any help greatfully received.
Posted 16 May 2007 - 07:53 PM
If not then you can get different ring gears that'll allow you to run verto/inertia or non-verto/pre-engaged, but I think you need to start with a new flywheel.
Better to swap the whole lot if you've got a later engine.
Posted 16 May 2007 - 08:18 PM
Yes i have got a verto flywheel that i could use but i want to keep the pre-verto clutch, are they compatable ?If you've got a verto flywheel and cover plate lying around, then just fit that, providing you fit the correct slave cylinder. Then you can use the inertia starter.
Posted 16 May 2007 - 08:20 PM
Posted 16 May 2007 - 09:30 PM
Any good engineer would be able to swap the ring gear for you, it only needs heating and smacking with a chisel.
Posted 16 May 2007 - 10:53 PM
Cheers Dan , i have a cooper, 1275 A+ with verto and have aquired an early 1275 A+ with pre-verto over bored +030 (does that make it a 1293) and no starter motor in it.Check the cluch FAQ. You can indeed put the pre-engaged ring gear on the pre-verto flywheel if you like but I think you also need to spacer out the starter motor from the drop gear case when you fit this combination. Can't quite remember off the top of my head, it's in the FAQ. All pre-verto flywheels would be innertia as standard. What setup do you have now?
So i`m wondering which is the best course of action ,should i just get an inertia starter or try and adapt it to take pre engaged , but after reading the clutch FAQ i want to keep the pre verto clutch.
Posted 17 May 2007 - 07:55 AM
Posted 18 May 2007 - 12:57 PM
Posted 18 May 2007 - 06:20 PM
Thanks for your help guys , just need to find an engineer now or fork out £100 ish for one already done from minispares, or has anyone got a verto flywheel for sale or swap for my spi one.If you get an engineer to put a pre-engaged type starter ring onto your pre-verto flywheel, remember to ask him to reverse the bevelled edge on the ring gear teeth before attaching it. The edge of the teeth are slightly chamferred on the side the starter pinion engages from. The earlier starter pulled the pinion gear in; the pre-engaged pushes it away from the starter body. I've seen the pre-engaged type ring gear fitted to a solid early flywheel with the chamfer on the same side as the original 107 tooth ring. That meant some careful work with a file!
