hi does anyone know if a 1380 supercharged A+ engine wil run any better with flat top pistons rather that dished because im in a bit of a pickle thatks
1380 pistons
big_dave
, May 17 2007 04:26 PM
4 replies to this topic
Posted 17 May 2007 - 04:26 PM
Posted 17 May 2007 - 04:33 PM
Depends what you want the compression ratio to be?!
Moved to Technical.
Moved to Technical.
Posted 17 May 2007 - 04:52 PM
Moved to Technical.
as well as what other factors are determining the CR
but generally you dont want too high a CR for a forced induction engine
Posted 17 May 2007 - 04:58 PM
With a Normaly Aspirated 1380 you would be struggling to get the compression ratio down with flat top pistons, never mind supercharging it.
Posted 17 May 2007 - 07:14 PM
you could run short height flat tops down the bore to keep the CR down.
